    Solved Bluetooth controller at first boot
    GamePad/GPIO/USB encoder
    bluetooth boot
    • zaccret
      zaccret last edited by
      Hello there,
      Is there any chance I can configure Recalbox without any USB keyboard / controller ? So far I only have the Wii classic controller with a Wiimote, will it be automatically paired at first boot or do I need a wired controller first ?
        OyyoDams Staff @zaccret last edited by
        @zaccret hi, it cannot be automatically paired but you can use the virtual keyboard via the web manager if you don't have any physical keyboard or other pad.
        zaccret 1 Reply Last reply Reply Quote 1
        • zaccret
          zaccret @OyyoDams last edited by
          @oyyodams thanks ! I did it with virtual gamepad in web manager from my smartphone
          101.4k
