    [SCRIPT] Generate CUE-Files for PS1 Game-Images
    Community projects
    [script] generate cue-files ps1 game-images
    • scal21
      scal21 last edited by
      hy guys i made a small python-script, which i want to share with you.
      it's called "createCue" and is a command-line tool, which does:
      • Automatically or manually generate a cue-File for every PS1 Game-Image
      • Backup your current cue-Files
      • The script will override your cue-Files, so make sure you have a backup of your current files.
      The script will create a cue file like this:
      If you have multiple Audio Tracks in your Game-Binary or multiple Game-CDs, you will still need a custom cue-File, in this case the Script will not work for you !
      Here a overview what it looks like:
      How can you use it:
      • Make a backup of your current cue-Files or let the script do it for you.
      • Download the script (tar-file) from the Link below
      • Copy the tar-file to your recalbox ( Path: /recalbox/share/system)
      • Connect to your recalbox by ssh or local.
      • go to the home-directory ( Path: /recalbox/share/system)
      • Unpack the tar-file: tar -xvf createCue.tar
      • Run the script: ./createCue.py
      Download Link Script
      100.7k
