    gamePad button configuration issue(connected through PC/PS3 PCB)
    GamePad/GPIO/USB encoder
    gamepad button issueconnected through pcps3
    • KC830
      KC830 last edited by KC830
      i used ras pi3 and recalbox 4.1 ver
      Installed by etcher
      2 joysticks are connected through pc/ps3 pcb to rRaspberry Pi
      Let's say 'Pad A' is on the left
      Pad B is on the right one
      Problem is ... when i use only one pad(pad B removed), everything's are fine with configuration
      but when i tried to use both pad , has a issue
      Pad B(on the right side) is keep taking Pad1 priority
      even i tried again and again when it says ' 2pads detected'
      if i tried to press a button of Pad A , it shows 'pad2' .....
      is there anyone who has the same issue and solved ?
      need a help ...
      100.7k
