    RecalBox x86 17.12.0.2 PSP not scraping
    recalbox x86 17.12.0.2 psp scraping
    • jammad4
      jammad4 last edited by
      Hi,
      I am new to game emulation, and I have set up a PC based recalbox on the latest version, and all the games work well under several of the consoles. The one issue I have right now is the PSP scraper. When I select the PSP console by its self in the main scraper I get the following message on the screen.
      "WE CAN'T FIND ANY SYSTEMS!
      CHECK THAT YOUR PATHS ARE CORRECT IN THE SYSTEMS
      CONFIGURATION FILE AND YOUR GAME DIRECTORY HAS
      AT LEAST ONE GAME WITH THE CORRECT EXTENSION.
      VISIT RECALBOX.FR FOR MORE INFORMATION."
      The PSP games run and they run very well, and I have reviewed the recalbox.conf. I was not able to find anything in the file that would help here, and the recalbox.fr is not a good site, e.g., it won't load for me. Instead, I went to recalbox.com and searched the forum for this issue/error but only found one post from over 2 months ago with no resolution.
      Any help here would be great I am almost done setting up my recall box which works great btw.
      jammad4 1 Reply Last reply Reply Quote 0
      • jammad4
        jammad4 @jammad4 last edited by
        @jammad4:
        I have also build a new clean boot and game USB drive from 17.12.0.2 and only added one PSP game. I get the same issue, and it does not matter which PSP games, it fails on all of them, and I have tested 5.
        Is anyone else having scraper issues with PSP on the PC/x64 version of recalbox?
