    No sound on Up Squared Board
    sound squared board
    3013
    • Grahf 0
      Grahf 0 last edited by
      I have no sound on my Recalbox. Everytime I go to the sound settings it has the system volume at 0. Everything else works fine except there's no sound. I tried my USB stick on a different computer and it had sound so I know it has something to do with my hardware.
      I'm using this system: http://www.up-board.org/upsquared/specifications-up2/
      Any help would be appreciated.
        Substring @Grahf 0 last edited by
        @grahf-0 hi
        which sound cards are listed in ES ? the volume at 0 is not such a big deal
        • Grahf 0
          @Substring thanks for the response
          Running the command "aplay -l" returned the following:
          https://pastebin.com/kejnmaAR
            @grahf-0 In ES, have you tried the different sound cards ? You shoul also have a look at TERM=xterm alsamixer (not sure about the TERM though, might be linux rather than xterm)
            • Grahf 0
              @Substring couldn't really do anything with Alsamixer. It wont let me change the volume in it either.
              I have tried selecting different sound settings in Emulation Station....
              • Grahf 0
                @Substring wow just tried it and I have sound. No idea what I changed.
                  Substring @Grahf 0 last edited by Substring
                  @grahf-0 grahf ... My worst enemy (have You played Xenogears on PS1 ? Haha)
                  You just changed the right mixers t have sound. Now just keep in mind that you'll have to do that againafter an upgrade, we have a bug where alsa mixers are reset to default upon upgrade
                  • Grahf 0
                    @Substring
                    I thought that was a picture of Fei. Xenogears is definitely one of the best. I've played it a couple times....
