    Turn my Raspberry Pi 0W into a bluetooth HID gamepad
    Community projects
    raspberry bluetooth gamepad
    • frowngo
      frowngo last edited by
      Hello there !
      I've been trying to get through this for weeks... many projects are quite similar but I have never found one that answers my problem.
      As the title says, I want to turn my Raspeberry Pi 0 W into a bluetooth HID gamepad.
      I figured out that another way is possible. Indeed you can create your own bluetooth HID device with either the Adafruit BlueFruit Ez-Key or a the RN-42 module (or even the HC-05 with the RN-42 firmware). But I want neither of these solutions.
      I want to use my Raspberry Pi 0 W in a way that it will be recognized as a bluetooth gamepad. Creating the gamepad is fine, I used the GPIO of the Pi for the inputs.
      But once the gamepad is physically done, how to make my Pi appear as a gamepad ? I've seen that you can use hciconfig in the terminal of Raspbian in order to change the class of the Pi and set it as a gamepad but I must admit that I didn't understand everything.
      And it's important that it appears as a gamepad and not as a keyboard.
      In a nutshell, I would like to turn my old wired nes controller in a bluetooth one, and play on another Pi where Recalbox is installed. (That's why you must appear as a gamepad and not as a keyboard, because Recalbox only works with bluetooth gamepads).
      Thank you in advance if someone takes his time to help me with this because I can't take it anymore haha !
        Substring @frowngo last edited by
        @frowngo i've never heard about anything that could do what you wish in linux. If i were you i'd look for some dedicated chip, i think adafruit has such
