    Xbox One S bluetooth controller and related
    GamePad/GPIO/USB encoder
    xbox bluetooth related
    • steve1977
      steve1977 last edited by
      I am currently using Retropie, but considering to switch to Recalbox as I have been reading good things about it.
      Before I do the switch, I'd like to understand three things. Would be great to get thoughts from the community:
      1. I have a bluetooth Xbox One S controller, which largely works with Retropie. Only the select button cannot be mapped. Does Recalbox support Xbox One S (bluetooth) and does the select button also works?
      2. Is on-board bluetooth for RPi 3 supported now?
      3. So far, I am only using one Xbox One S bluetooth controller. I am considering to buy 1-3 more to play multi player games. How do I need to map the 2nd, 3rd and 4th controller?
      4. I am also planning to use moonlight to play PC games. I read about many issues related to multi-player support. Will the controllers work as mapped in Recalbox or do I need to somehow map them again in Moonlight?
        voljega Banned @steve1977 last edited by
        @steve1977 the on-board bluetooth is supported but it's crappy hardware anyway, it's better to have a dedicated one
          Substring @steve1977 last edited by
          @steve1977 said in Xbox One S bluetooth controller and related:
          So far this controller is not supported witbout some.user side trick. Select doesn't work for now, as well as triggers it seems
          1. Is on-board bluetooth for RPi 3 supported now?
          Yes, but it's dreadful
          1. So far, I am only using one Xbox One S bluetooth controller. I am considering to buy 1-3 more to play multi player games. How do I need to map the 2nd, 3rd and 4th controller?
          You don't have to do anything regarding this on recalbox. The emulators configuration is dynamic
          1. I am also planning to use moonlight to play PC games. I read about many issues related to multi-player support. Will the controllers work as mapped in Recalbox or do I need to somehow map them again in Moonlight?
          Work as mapped in Recalbox. I haven't tried multiplayer Moonlight for a while, but it used to work for sure
          • steve1977
            Thanks for your quick replies. Can you elaborate what you mean by "user side trick"? Also, any plans to add support for this controller? I have two of them and would prefer not to buy new ones.
              @steve1977 give a try to https://forum.recalbox.com/post/84335
