    PS3 joystick vibrates non-stop
    GamePad/GPIO/USB encoder
    ps3 joystick vibrates non-stop
    2674
    • chiky
      chiky last edited by
      Hello!. When I connect my generic ps3 joystick to the raspberry it starts to vibrate without stopping. The joystick works perfectly, but it is really annoying to play with a joystick that does not stop vibrating.
      Any solution for this?
      Sorry for my bad English.
      Thank you very much!.
        Substring @chiky last edited by
        @chiky disable ps 3 controllers in recalbox.conf.
        Why don't you play on bluetooth ?
        chiky 1 Reply Last reply Reply Quote 0
        • chiky
          chiky @Substring last edited by
          @substring It is a good solution, but I still have the problem when connecting the joysticks to the raspberry to charge your battery 😞
            @chiky charge the battery elsewhere
            • chiky
              @substring I appreciate the help, but that is an alternative solution. I would like to charge the joystick battery from the raspberry, for that reason I am looking for a solution to the problem of vibration. Likewise, Thank you very much for your help!
                @chiky for now there is no.solution but to either disable bt on ps3 pads or patch the kernel
