    Reset FBA_libretro core/configuration to default
    Emulator Arcade/PC/Console
    reset fbalibretro default
    • RandomTask
      RandomTask last edited by
      Happy Holidays, everyone!
      I've updated my Recalbox to the current version and I think I've made an oopsie with the FBA_libretro core. I originally configured my Neo Geo games to automatically run in freeplay mode and to use a modern button layout instead of the classic one. The update seems to have changed something about the button layout because it was different than before. I must've made a mistake when I tried to reverse it, because now "Configuration override loaded." is displayed when I start a game in FBA_libretro and I can't seem to change it. Is there any way to reset my configuration/core to default?
      Thanks in advance.
        Hello @RandomTask
        check in /recalbox/share/system/configs/retroarch
        • RandomTask
          Games still display "Insert coin" when booted, even though they were set to Freeplay. Fatal Fury Special for example:
          fba-dipswitch-fatfursp-Free_play = "On"
          It seems that the dipswitch settings were overwritten since it also displays the credit level, even though I turned it off in the dipswitch settings.
          I've edited
          fba-neogeo-controls = "newgen"
          as well as
          fba-neogeo-controls-p1 = "newgen"
          but Garou: Mark of the Wolves still uses the "classic" button layout.
          Is there something specific I should look for in either retroarchcustom.cfg or retroarch-core-options.cfg?
