    Theme Arma (1920x1080)
    Themes & Interface
    theme arma 1920x1080 1080
    7
    8
    6594
    • Marcello Armanini
      Marcello Armanini last edited by Marcello Armanini
      Hi all,
      this 's my own first theme for Recalbix 4.1 :
      • 1920 x 1080 resolution
      • all systems supported
      • 138Mb
      Any suggestions are appreciated.
      An example about the theme
      https://www.instagram.com/p/BdAoAs6D1Rr/
      Download here...
      Arma theme
      (sorry for the bad photos...)
      OyyoDams Substring Larlouch 3 Replies Last reply Reply Quote 0
        OyyoDams Staff @Marcello Armanini last edited by
        @marcello-armanini Hi,
        Thanks for your work. I have not tested your theme yet. However 1920 x 1080 seems to be a huge resolution. Did you try to enable all systems on a Raspberry PI ? No memory issue ?
        Marcello Armanini 1 Reply Last reply Reply Quote 0
        • Marcello Armanini
          Marcello Armanini @OyyoDams last edited by
          @oyyodams hi, i tried to enable 21 systems and the theme work fine on my raspberry pi 3.
          I didn't try all 50 systems cause i haven't a rom for every ststem...
          In next days i'll try to find at least a rom to check every system.
          • kjbstar
            kjbstar last edited by
            I thought it was ArmA ;D #sadness
            • Guillaume Vincent
              Guillaume Vincent last edited by
              nice one ! not all items are showed correctly on my screen, but a little adjust and everything will be ok !
              thanks for the work
              • Cthulhus
                Cthulhus last edited by
                nice one !
                C'était mieux avant :-)
                  Substring @Marcello Armanini last edited by
                  @marcello-armanini you can make much nicer screenshots with the webmanager
                  Are all the background images your work ? What is the license of the theme ? It happens too often we see some themes that are a revamped version of another theme without crediting the original author ...
                  • Larlouch
                    Larlouch @Marcello Armanini last edited by
                    @marcello-armanini
                    Beautiful theme!
                    For my information I would like to know which game is the music used for the system snes?
