    DOSBOX fullscreen 16/9 (recalbox 4.1 17.12.02)
    Emulator Arcade/PC/Console
    dos
    • Arbatax
      Arbatax last edited by
      Hi all, maybe the solution is already in the forum but i cannot find it. Basically, when i am playing a game into dosbox (recalbox 4.1 17.12.02) the game is working but only in 4/3 aspect mode. I am playing my raspi on a TV and i would like to view it in 16/9.
      I was fighting with dosbox.conf, with options of scaling and nothing happened. Maybe i am doing something wrong. I don´t know.
      For sure you guys have the correct keys to touch. Any help will be really appreciated.
      Thanks in advance
        voljega Banned @Arbatax last edited by voljega
        @arbatax do a copy of odsbox.conf in your game folder, rename it to dosbox.cfg then change aspect=true to aspect=false inside it.
        If this doesn't change anything or if the parameter was already set to false, I don't think you can do anything else... then well those old games are 4/3 anyway 🙂
        Arbatax 1 Reply Last reply Reply Quote 0
        • Arbatax
          @voljega
          Hi voljega. Thanks a lot for your early reply!!
          I have read all your previous posts. You did a great job with dosbox knowledgebase.
          So. I will leave aspect=true in the main dosbox.conf
          and aspect=false in the new file dosbox.cfg inside the game folder. Im gonna do it in 1 minute and will report back the findings. Thanks again body.
          • Arbatax
            Arbatax @voljega last edited by
            @voljega
            Hi again. I did it with no success.
            It is a pitty but i was wondering that I missed some parameter becasue in my computer i normally play the same games in 16/9 with no scaling and works perfectly.
            Thank you anyway man
            101.4k
