    Unsolved XCSOURCE 2 Joueurs Encodeur USB only works in the main menu
    GamePad/GPIO/USB encoder
    xcsource encodeur usb main
    • Florian Schmidt 0
      Florian Schmidt 0 last edited by Florian Schmidt 0
      Hi Guys
      im looking forward to build my first arcade. Now i cant find out how to configure the recalbox to make XCSOURCE 2 Joueurs Encodeur USB work. When i go to Controller Setup he is found, i can set the buttons everthing looks fine. As soon as i start a emulator (SNES, MAME, PSX) the buttons and the joystick stop working.I added usbhid.quirks with the ID i found for the SCSOURCE2 in the cmdline.txt but nothing happend. It only works in the main menu. I also tried dmesg where i can see the it is there. And a test with evtest showed that all buttons work. So where can i find a solution now?
      my recalbox-support.sh:
      https://file.ac/x-UZwgidZ6o/
      • Florian Schmidt 0
        i just found out that the Encodeur works in the N64 Emulator. But still not in the other ones. Any ideas?
        101.4k
