    CLEAN ROMS MAJHONG OF FOLDER FBA_LIBRETRO ?
    Emulator Arcade/PC/Console
    clean roms majhong fbalibretro
    • jose-manuel-perez
      jose-manuel-perez last edited by
      Hello, I've been doing the whole weekend with programs but every day I'm more involved, what I want is to clean the Majhong roms, Poker, Quiz, etc ...
      Is there a program that does it? any tutorial?
      Regards, and thank you very much
      • coldnpale
        coldnpale last edited by
        Not sure if this is what you mean... but I am using this great little GameList editor: https://forum.recalbox.com/topic/9265/soft-gamelist-editor
        You can activate the "god-mode" and then you'll be able to select and remove roms, as well as the entries from the gamelist.xml.
        You just have to give the path of the roms folder.
