    How do I enter in noobs in 17.12.02
    enter noos 17.12.02
    2649
    • Genaker
      Genaker last edited by Genaker
      Hi there,
      I need to enter in noobs in Recalbox 17.12.02, I need to change the config.txt, I want to configure my recalbox to use it in a old CRT TV.
      Before this version I was able to enter using a keyboard during boot (pressing shift), now during boot I'm unable to enter using "shift" with my keyboard.
      Thanks for your support
        Substring @Genaker last edited by
        @genaker if you used the .img, noobs is not included. You need tout manually edit the file
        • patriccote
          patriccote last edited by
          @Substring can you give the path to the /config.txt file ? I would give it myself but I'm at work so I can't confirm it.
          patriccote
            Substring @patriccote last edited by
            @patriccote it's /boot/config.txt. Don't forget to mount -o remount, rw /boot if you wish to edit it. I strongly recommend doing it through WinSCP for people not used to keyboard-only editors
            • Genaker
              I don't know how to use WinSCP, can you give me a little more help?.
              Thanks for your support.
                @genaker there are tutorials, even on our own youtube channel
