    Is the pi0-w internal wifi supported?
    • Chris Broughton
      Chris Broughton last edited by
      My pi zero w says "not connected" under network settings despite having the correct SSID and Password for my WPA2 network.
      I'm finding it hard to find current, definitive, information saying whether the internal wifi of the pi0-w should work with the current pi1/pi0 image release from http://archive.recalbox.com/
      Is the internal wifi supported?
        Substring @Chris Broughton last edited by
        @chris-broughton the pi0w is fully supported wifi AND bt
