    3.5mm Audio/Video Jack Problem
    3.5 no video conly audio vrt rpi2 tp-link t
    5307
    • escipion
      escipion last edited by
      Hello, I want to connect the raspberry pi through connector 3.5 jack. But I get only sound and no video, I need some settings?
      • mike-luetjens
        mike-luetjens last edited by
        No, you might have the wrong cable.   I needed to buy 2, one doesnt work at all. (Was a cheap one for apple devices), the second does work, however, i had to switch red (Audio Right) with yellow (Video) on my tv to get it running. At a second TV, I also need to use a Scart Adapter, otherwise the picture is only Black and White.
        • digitaLumberjack
          https://github.com/digitalLumberjack/recalbox-os/wiki/Connect-your-recalbox-to-a-CRT-with-composite-(EN)
          • escipion
            No Mike, I have the correct cable, built it   Thx Lumberjack, im going to try that later
            • escipion
              one question, where is the location of the file config.txt?
              • lordtaki
                lordtaki last edited by
                /boot/
                • escipion
                  thx  lord, i just funded. Still can't get any video from the composite
                  • escipion
                    The cable wokr, i tested So, i dont know if you can tell me whats is wrong with the config.txt
                    • escipion
                      Finally, i just have to reinstall the OS, in noob you change the format of the TV, and install and work just fine. the config.txt put that on the bottom
                      • digitaLumberjack
                        Hi, if you look closely at the link i gave you, it's exactly what i tell you to do :
                        comment all lines begining with hdmi_
                        sdtv_mode=2 hdmi_ignore_hotplug=1
                        An i explain the different modes for sdtv.
                        • escipion
                          <span style="color: #212121; font-family: inherit; white-space: pre-wrap; line-height: 1.5;">Yes, I did that , use the wiki you passed me . But I could not make it work . With a new installation, and run the NOOBS from the RCA , and it worked without problems</span>e
                          • digitaLumberjack
                            That's because you did not commented all hdmi lines in your config.txt : at the end : # NOOBS Auto-generated Settings: hdmi_force_hotplug=1 config_hdmi_boost=4
