    Configuring LCD display?
    configuring lcd display
    • guilherme-vieira
      guilherme-vieira last edited by
      Hi, recently I got a LCD 3,5 inch tft display. I search the web and found out that I need to use few commands as sudo REPO_URI=https://github.com/notro/rpi-firmware rpi-update but whenever I try to use commands like this I get the error message: -sh:sudo: not found   Is there any way so I could use this kind of command to install the drivers for my lcd? Thank you.
      • digitaLumberjack
        Hi, rpi-update is not in recalbox. You cannot (for now) use your LCD 3.5 inches. Sorry 😞
        • guilherme-vieira
          Oh, ok, thank you for you answer! Keep the good job going.
