    GPIO Pin
    Your recalbox
    gpio pin
    • Nicola Silveri
      Nicola Silveri last edited by
      Hi,
      how can i change the pin for buttons with mk_arcade? i have only up, b, start and select working.i have this hardware configuration:
      |BUTT:GPIO_PIN|
      |up : 18| OK
      |down : 12|
      |left : 7|
      |right : 8|
      |LT : 16|
      |LR : 1|
      |A : 20|
      |B : 25| OK
      |start : 24| OK
      |Select : 23| OK
        Substring @Nicola Silveri last edited by
        @nicola-silveri Hi
        have a look at https://github.com/recalbox/mk_arcade_joystick_rpi#loading-the-driver, i'm not sure recalbox has that feature. The parameters can be edited in the recalbox.conf. But you'd need Recalbox 4.1 at least. But I can't tell for sure we handle that for now
