    Unsolved v17.11.10.2 issue with N64 controllers
    n64 17.11.10.2
    • Schim57300
      Schim57300 last edited by
      Good evening,
      I have a 8Gb SD card with a recalbox 17.11.02.
      Everything works fine. I have succeeded with the setup of my N64 controllers (through the ~/configs/mupen64/InputAutoCfg.ini file)
      I bought a 32Go and I installed the version 17.11.02 then I upgraded it to 17.11.10.2
      The configuration is the same:
      • Copy/paste of ~/configs/mupen64/InputAutoCfg.ini
      • Add the same parameters from one recalbox.conf to the new one (n64.configfile=dummy)
      My problem
      With the 17.11.10.2 when the "C Button Up" (yellow button of N64 controller) is pressed, the game is left and I m back to the recalbox menu.
      Would you mind helping me please? Is that a bug? Did I miss something?
      I do not want to upgrade my 8Gb card from 17.11.02 to 17.11.10.2 since I'm affraid I won't be able to play anymore.
      Thanks in advance
      Eric
        Substring @Schim57300 last edited by Substring
        @schim57300 hi
        Changelogs are complete with no secret change. Otherwise we can't even track ourselces evolutions from a version to another
        Still ,it looks like you messed up your hotkey with that c button
