    Update 4.1 - PSP, PSX, DC :(
    Your recalbox
    update 4.1 psp
    5010
    • Mr. Kilroy
      Mr. Kilroy last edited by
      Good day to all! I'm new, so I decided to ask (clarify).
      Did I understand correctly that not all games have been tested for PSP, PSX, DK and we need to compare the list with "RECALBOX Compatibility Lists" ???
      The question is - I understand that games on these game emulators work poorly, will it be fixed or updated?
      I would like to play "God of War", but he is very slow
        Substring @Mr. Kilroy last edited by
        @mr-kilroy Wanna play god of war on which system ?
        There are some compatibility lists, yes. I don't know the links
        • Mr. Kilroy
          I have a Raspberry 3 ... I installed a new version of it. But the game is on it. Here's the question whether this will fix it or is a problem due to the low power of Raspberry 3 ?????
          • unik314r
            unik314r last edited by
            "which system" means which "entertainment system" : super nintendo, playstation etc...
            • Mr. Kilroy
              PSP, "God of War" is not on other systems 😉
              I so expect that with PS1 and DC the same situation, with braking games...
              • Moon
                Moon last edited by
                I THink here is a specific box to tick in the ppsspp graphic option to speed up GOW. Did not check myself, but it is worth taking a look.
                • Mr. Kilroy
                  @moon said in Update 4.1 - PSP, PSX, DC 😞:
                  Could you be more specific?)
                  • Moon
                    Moon last edited by
                    If I'm not mistaken :
                    • launch any psp game.
                    • press hotkey+a (or b ?) to get into the ppsspp emulator interface
                    • go to graphic options
                    • there is a parameter to tick (or untick) that speeds up GOW according to the description.
                    I did not try it myself, I dont have any GOW isos.
                    Let me know if it works out for you !
                    • Mr. Kilroy
                      Unfortunately, this did not help. The game slows down
                      • Mr. Kilroy
                        So no one knows what the problem is? Or games so far and will slow down, until they fix? (PSP)
                        • cissou
                          cissou last edited by
                          The pi3 lack of power for most of the PSP games, principally the GOW ones
                          Dell 3020M + X360 sans fil
                          Bartop Modulaire : Rpi3
                          • Mr. Kilroy
                            Ie in RI3 does not have enough power to run games ???
                              @mr-kilroy you can still tweak the emulator for better perfomances
