    Storage error
    storage
    • neimi
      neimi last edited by
      me again ... Since my last post here was the system actually quite good. first time my current problem/effects: -recalbox boots no longer in KODI -system settings show: Storage Error -Controller are no longer recognized and can not be configured -in KODI the PVR-client no longer works, even though it is enabled (can not be disabled) what have I done today to the problem occurred: -Wireless adapter for XBox360 controller connected -XBox360 Controller configured -added ROMs -various ROMs tested (Mario Kart 64, Dr. Mario, Tetris ...) -scraping -played Dr. Mario -scraping again -> error can not save pictures, card full -Change to KODI -> PVR Client Error see above I just really wanted to post the log, but after a new reboot I no longer get a connection per ssh on the RPi2 šŸ˜ž KODI shows network connection: Not connected
      • digitaLumberjack
        Hi, if you go in ES option system, do you see the space remaining on the partition ? Can you connect on the CLI and use a df command to see what's left on your card ? What is your card size ?
        • neimi
          Thanks for your answer, but its too late... I“ve make a new installation yesterday... I don“t no what ES is, but if i was boot into noob the remaining space was only 64MB, so i couldn“t install over the existing system. My card size is 32GB. I tried to rescue the SD-Card with TestDisk, but the Share-Partion couldn“t be recoverd.
          • digitaLumberjack
            Es os emulation station the frontend. The noob partitions you see on your pc have nothing to do with the system you cant see remaining space from there.
            Copyright Ā© 2021 recalbox.com
