    Dreamcast PS3 controller configuration error
    GamePad/GPIO/USB encoder
    dreamcast ps3
    4555
    • ishim7924
      ishim7924 last edited by
      Hey, what's up guys, i recently updated recalbox to v17.11.02, and installed Dreamcast emulator on my recalbox, but it started to have some problems. The emulator works fine, but it has a problem with the analog left stick of my gamepad. I have two PS3 dualshock 3 controllers, and the thing is that, when you move to left or up, it goes to the opposite side. I tried changing the gamepad mapping configuration file on reicast, but the problem still remains. Does anyone know how to fix it?
      abunille xtreemsurf 2 Replies Last reply Reply Quote 0
      • abunille
        abunille @ishim7924 last edited by
        @ishim7924
        Hi,
        change the PS3 Driver in recalbox.conf to bluezand try again.
        ishim7924 2 Replies Last reply Reply Quote 0
        • ishim7924
          ishim7924 @abunille last edited by ishim7924
          @abunille i will give it a try, thanks
          • ishim7924
            @abunille still not working 😞
            • xtreemsurf
              xtreemsurf @ishim7924 last edited by
              @ishim7924
              I'm also having this problem with Wii U Pro controllers and the Dreamcast emulator. The D-pad works fine, but the left analog stick is reversed. Does anyone else have a suggestion? Thanks!
              • ishim7924
                ishim7924 last edited by ishim7924
                I tried to use my 8Bitdo NES30 Pro Controller to see if the same error remains. funny fact, there is no problem with the NES30 Pro, it works perfectly
                xtreemsurf 1 Reply Last reply Reply Quote 0
                • xtreemsurf
                  @ishim7924
                  Thanks for the info. I did a little more testing and found out that the controls work perfectly if I don't press the analog stick all the way to the edge. As soon as I push the analog stick more than 80% to the edge in any direction, it makes me go the opposite direction on the screen. Is there a way to fix this...maybe by setting the sensitivity or dead zone?
                  Edvis 1 Reply Last reply Reply Quote 0
                  • Edvis
                    Edvis @xtreemsurf last edited by
                    @xtreemsurf on my joystick: 0_1510592171990_Screenshot_49Z.png
                    • xtreemsurf
                      xtreemsurf @Edvis last edited by
                      @edvis
                      Thanks for that update on your controller. So the problem includes PS3 controllers and Wii U Pro controllers...and only with the Dreamcast emulator. I'm going to pull out an old Saitek controller and hopefully try it out tomorrow. Crazy Taxi & Soul Calibur can be played with the D pad, but Sonic Adventure requires the analog stick.
                      • xtreemsurf
                        I had an interesting find today. I recently bought a Nexilux Game Genie Controller adapter from Amazon for $20, to use my Wii U Pro controller on my PC. Well, I decided to try it with Recalbox. When I connect my Wii U Pro controller to Recalbox through the Nexilux adapter, the analog stick works perfectly! I didn't have a chance to try it with a PS3 controller yet.
                        • Edvis
                          in some dreamcast games there are still problems with analog UP
                          • Edvis
                            Edvis @xtreemsurf last edited by Edvis
                            @xtreemsurf
                            At me if more than 30% you will press that not correctly works
