    Suggestion. Avoid custom splashvideos to be removed with newer updates
    Themes & Interface
    suggestion avoid splashvideos removed newer
    3910
    • kelv
      kelv last edited by
      Hello
      I would like to suggest to avoid the overwrite of custom splash intro videos with every update. I'm not a fan of the default one and even it's too noisy I would like to keep mine.
      THX
      Raspberry Pi model: RPi 3b+
      Recalbox build : 7.0.1 DragonBlaze
      Hardware: MicroSD UHS 128 GB up to 80 MB, Class 10 and 2.5 A Power Supply.
      Overclocked: 1485 MHZ
      Controller(s): Wired Xbox 360 PAD (working perfectly on any other game/emulator).
        rockaddicted @kelv last edited by
        @kelv Our splashscreen is a part of the project's identity.
        So we will not help rebranders in their work that don't respect our job.
        If you don't like the current video splashscreen, you can suggest a new one integrating the recalbox logo, and Royalty-free music.
        If you are developer you can suggest too an option to manage sound during this splashscreen.
        • kelv
          kelv last edited by kelv
          hello @rockaddicted
          • Concerning the video volume. Yes I'm a computer Science engineer and i used to a developer. Per your suggestion, I downloaded the source code from git and I was doing reverse engineering. I see that the logic lives in S02Splash located at etc/init.d. I see that there is no volume switch either omxplayer nor ffplay. Adding the switch " --vol -yourvalue" to the line omx_opt="--adev both --no-keys --layer=10000 --aspect-mode=fill" will help to increase or reduce the volume (that's for rpis for other systems it's in another code block as it uses ffplay and the switch has to be -volume) . A new menu item in ES could be developed to read that switch and modify it.
          • Concerning the video. I'm quite surprised about the answer (btw I didn't want to be mean) However Recalbox project enables and leverages the community to modify the theme but it seems that doesn't enable us to modify the video. I'm sorry but I don't understand.
          • Concerning avoid deleting the video. Checking how recalbox deploys when it is installed or updated, it's needed a script to avoid smashing custom videos for checking the video size and date and if it's different than the default one, do not smash it.
          • BTW If I want to contribute to the project, how can I do it? My Cpp knowledge is quite rusty and I'm better C# and Java developer. I also see that there is a lot of Python that I have no knowledge but I can learn.
          THX
          BTW, This is the code snippet of the file.
          #code snippet code
          do_omx_start ()
          # odroid xu4 has not omxplayer, make it run this code make it flash
          if [[ ! -f $video || ! -f /usr/bin/omxplayer ]]; then
          return
          fi
          # Initialize dbus session
          OMXPLAYER_DBUS_ADDR="/tmp/omxplayerdbus.root"
          OMXPLAYER_DBUS_PID="/tmp/omxplayerdbus.root.pid"
          exec 5> "$OMXPLAYER_DBUS_ADDR"
          exec 6> "$OMXPLAYER_DBUS_PID"
          dbus-daemon --fork --print-address 5 --print-pid 6 --session
          until [ -s "$OMXPLAYER_DBUS_ADDR" ]; do
              echo "waiting for dbus address to appear" >&2
              sleep .2
          done
          DBUS_SESSION_BUS_ADDRESS=`cat $OMXPLAYER_DBUS_ADDR`
          DBUS_SESSION_BUS_PID=`cat $OMXPLAYER_DBUS_PID`
          export DBUS_SESSION_BUS_ADDRESS
          export DBUS_SESSION_BUS_PID
          # Launch the video
          omx_fnt="--font=/usr/share/fonts/dejavu/DejaVuSans-BoldOblique.ttf"
          omx_srt="--no-ghost-box --lines=1 --align=left $omx_fnt --font-size=20 --subtitles=/recalbox/system/resources/splash/recalboxintro.srt"
          /usr/bin/omxplayer.bin $omx_opt $omx_srt $video &
          PID=$!
          voljega Gaetan 2 Replies Last reply Reply Quote 1
            voljega Banned @kelv last edited by
            @kelv said in Suggestion. Avoid custom splashvideos to be removed with newer updates:
            Most people modifying the video or before that, the splash screen do it to resell illegally Recalbox under their own brand.
            This is why modifying the video in any way has no official support by the team.
            • kelv
              kelv last edited by
              THX @voljega that makes sense.
                The way wanted to do is using the volume setting defined by users in recalbox.conf file.
                But, during the video splash screen init, by S02Splash, share partition is not mounted.
                So we can't access to the volume settings defined by user in /recalbox/share/recalbox.conf.
                First thing to do should be to delay the splash init after the /boot partition mount and manage this setting using /boot/recalbox-boot.conf file.
                That is something to check once our upgrading system will be b*mped.
                If we move init scripts order, that will be the chaos...
                kelv 1 Reply Last reply Reply Quote 0
                • kelv
                  kelv @rockaddicted last edited by
                  @rockaddicted uff. I think is better to keep it as is
                  • Gaetan
                    Gaetan Theme moderator @kelv last edited by
                    @kelv i didn't anderstand your code language, but i definitly like it ^^
