    Seeking for jamma control driver. for pcx64
    pc to jamma paraller port psxpad linux
    2713
    • Javier Sandoval
      Javier Sandoval last edited by Javier Sandoval
      Ok, so, in the windows emulation world, i like to use this grea old , i call them encoders but im not sure what the correct name is, wich are pc to jamma, i dont used the vga por anymore as its easyer to use lcd directly to the computer, i just really use them for the controllers and the sound, the sound works directly, no need for a driver, so does the vga, it only uses a driver for the controllers wich in reallity are 3 snes chip controller. Now in the old DOS days we used, sneskey, wich you can find information a bout it here
      snes key 9
      Now as years passed, in the hyperspin with windows 7 years i used psxpad driver wich i download from here
      psxpad
      and because this thing manages the snes controllers via parallel port, i cant seem to find acurate information , but on this page
      snes control via parallel port
      so i was wondering if theres a way or a driver you guys can help install to use this on pc.Or if is allready implemented what do i need to do. Thanks for any help.
      alt text
        Substring @Javier Sandoval last edited by
        @javier-sandoval Could you detail how you expect to expect that to your pi ?
        Javier Sandoval 1 Reply Last reply Reply Quote 0
        • Javier Sandoval
          Javier Sandoval @Substring last edited by
          @substring said in Seeking for jamma control driver. for pcx64:
          Tittle says for pc , and the controllers conect to a paralel port.
            voljega Banned @Javier Sandoval last edited by voljega
            @javier-sandoval when was the last time you bought a new pc with a parrallel port ?
            Haven't seen one in ten years I think. Maybe fifteen
            • Javier Sandoval
              Javier Sandoval @voljega last edited by
              @voljega said in Seeking for jamma control driver. for pcx64:
              as a matter o fact i buy old pcs all the time, i dont live in the US or Europe, here in mexico a dual core o core dos duo pc goes betwen 15 to 30 bucks, with around 2gb ram ,pretty decent for old emulation. Tomorrow im a buy one more, and those pc to jamma things, are around 15 bucks, you can solder the cables or save time with a jamma harnes.Plus its easy to buy local, no need for shipping.
                @javier-sandoval ok i remembered that you spoke about it a while ago and tht's why I spoke about new computers nit old ones.
                I don't think it would work well on such an old computer and i don't think recalbox handles parallel port and neither that the 2.5 developers team will have time to code to support something which disapeared ten years go
                • Javier Sandoval
                  Well, recalbox runs super smooth on this old pc, eve psx ad n64 games runs flawlless and no errors, so no, you dont need a new pc for recalbox, i still use hyperspin, and it does run well, and for the ones that like dreamcast or newer games , a decent old video card does the job too. And about jamma being death for 10 years, boy you couldnt be more wrong, this things are still sold normal, and whoever invented this, they even developed one for the original xbox, one for ps2 and we have another for xbox 360, i just happen to use the pc one, theres one that uses usb controls but that one goes for abour 30 bucks, i might buy one and try with recalbox, as i do understand developers not wanting to workfor a feature that not many people find usefull. Thanks anyway.
                    @javier-sandoval I meant off course parallel port not jamma
                    Good thing that such old computers work fine !
