    Unsolved Issues with TV on 4.1 Pi3
    4.1 pi3
    • ignign0kt
      ignign0kt last edited by
      So I have this strange issue with video glitching. Sometimes when booting up, the boot animation and sound with freeze and the audio will keep looping a short clip over and over. Just rebooting usually fixes that.
      But a bigger issue is terrible constant video glitching (like this https://streamable.com/4q4dz). It seems to happen at random times, but almost always happens when launching a game.
      What's weird is, turning off and on my TV again will clear the glitch temporarily. But when I exit the game back to ES, it happens again.
      I thought it could be a TV issue, because I haven't seen it happen when hooked up to a monitor. However, none of my other devices or computers do this when hooked up to my TV, so it's something between the TV and the Pi3 specifically.
      But also, it didn't happen on 4.0
      Could there be certain video settings in recalbox that could cause this? Or any changes to 4.1?
      ignign0kt 1 Reply Last reply Reply Quote 0
      • ignign0kt
        ignign0kt @ignign0kt last edited by
        Guess I spoke too soon. I had a computer hooked up to the same HDMI port and I eventually got the same issue when rebooting it. Must be a TV issue.
        Tried to delete the thread but couldn't.
        • abunille
          abunille @ignign0kt last edited by
          @ignign0kt
          Good morning,
          no problem, i mark it as solved.
          For the future, you can do it yourself:
          Topic Tools -> Ask a question + Topic Tools -> Mark as Solved
          • ignign0kt
            So Vizio has actually told me that it may be a resolution issue from the Pi3 because the HDMI port that I'm using (I need to use this particular port because it's the lowest latency port) is meant for:
            2160@60hz 4:2:0 Chroma 10-Bit color
            1080@120hz 4:4:4 Chroma 10-Bit color
            Is there a recent change in 4.1 that could have affected the video output? Because this only started happening with 4.1. 4.0 was always fine.
            Even though it seems to be sporadic in 4.1
            I'm not seeing 1080p @ 120hz as an option here https://elinux.org/RPiconfig
            Is that option just not possible on the Pi3?
