    Solved PCEngineCD issues loading issues
    pcenginecd loading
    • kelv
      kelv last edited by
      Hello
      I'm still having issues with PCE. Now I try to run the japanese version of R-type and the Japanese version of Gradius 2 and it's failing. When I get the logs I have a segmentation fault
      /usr/bin/retroarch -L /usr/lib/libretro/mednafen_supergrafx_libretro.so --config /recalbox/share/system/configs/retroarch/retroarchcustom.cfg /recalbox/share/roms/pcenginecd/R-Type_Complete_CD_(NTSC-J)_[ICCD1001].cue
      Segmentation fault
      Can anybody help me to troubleshoot this?
      THX!!!
      Raspberry Pi model: RPi 3b+
      Recalbox build : 7.0.1 DragonBlaze
      Hardware: MicroSD UHS 128 GB up to 80 MB, Class 10 and 2.5 A Power Supply.
      Overclocked: 1485 MHZ
      Controller(s): Wired Xbox 360 PAD (working perfectly on any other game/emulator).
      • kelv
        kelv last edited by kelv
        I found my problem. It's not supported the combination of Iso+cue. We need bin+cue PLS Mark it as solved. THX
        • kelv
          kelv last edited by
          Forgot to say that the info in the cue file is case sensitive even the bin word. bin should be in lower case normally is uppercase.
