    problem with images
    • alexmax
      alexmax last edited by
      I put some folders with the images (I used universal xml scramble ) in the roms folder but the recalbox doesn t see it.
      Where can I write the right root for the images???
      • Maldorhan
        Maldorhan last edited by Maldorhan
        The paths to each game images are in the gamelist.xml files, located at the root of each console folder
        RPi0W / Retroflag GPi CASE
        RPi3B+ / Retroflag SUPERPi CASE-J
        Retroflag NESPi CASE v1
        • alexmax
          It doesn t work. I try to replace and also to change and save (with notepad++) the xml files with the right path inside every folder rom ...but when I restart the recalbox the xml file come back empty
          • Adriano Luiz de Souza
            Adriano Luiz de Souza last edited by
            Try Stop EmulationStation before run scrape in UXS.
