    Solved Colecovision Black Screen Crash To Gameslist
    Emulator Arcade/PC/Console
    colecovision crash gameslist
    • ShoeHornOPlenty
      ShoeHornOPlenty last edited by
      Fairly new to Pi and Recalbox so please forgive me if I am missing something obvious.
      I have a Pi3 with Recalbox 4.1 and all my other systems are working ok except the new Colecovision emulator.
      My roms all have .col extensions and I have installed a Bios through the Web Interface however the issue is the same with or without the Bios installed.
      Everytime I load one of the roms the screen goes black for a few moments then kicks me out back to my gamelist.
      Has anyone experienced a similar issue and if so how was it resolved?
        Hi did you had required bios files ?
        check readme.txt files in rom folder for more informations.
        • ShoeHornOPlenty
          Hi Rock and thanks for the reply. I managed to resolve the problem by downloading the necessary files from the readme again. I think the first time i downloaded maybe it was corrupt or something.
          All seems to be working fine now, thanks again!
