    No Mame names after update
    mame names update
    4321
    • dinkydinkypoo
      dinkydinkypoo last edited by
      After updating to 4.1 my Mame list shows only the coded names not the actual game name. This makes scraping or even simply looking for a specific game almost impossible. I'm using Mame set 0.78. This was not a problem in 4.0. Is anyone else having this problem and does anyone have a fix?
        voljega Banned @dinkydinkypoo last edited by
        @dinkydinkypoo yeah this is a new thing in 4.1 but it shouldn't forbid scraping ? sure it doesn't work ?
        • dinkydinkypoo
          @voljega Yea, it doesn't seem to scrape at all. The scraper just skips through all the games in a couple seconds and doesn't recognize anything. It says I don't have a system set but I'm pretty sure I do or I don't know how to.
            @dinkydinkypoo ok you should ask on the thread about UXML scrapper then
            • Michigen
              Michigen last edited by
              Yeah...i have the same problem...i tried so many ways to fix that, but no chance.
              If someone had a solution I would be pleased
              frankie842 1 Reply Last reply Reply Quote 0
              • dinkydinkypoo
                Hey @voljega, I'm still having no luck. Any idea why they decided to use the file names for Mame instead of true names? Where can I find the umxl scraper thread? I've looked for it but can't find it. I'd love to try the other features of 4.1 but it's basically useless to me if I don't figure this out. I can't have a stand up arcade cabinet if the people playing it can't find the games they want.
                  voljega Banned last edited by
                  https://forum.recalbox.com/topic/4690/soft-universal-xml-scraper-v2/631 and add @screech for him to get a notification
                  • dinkydinkypoo
                    Thanks @voljega but I think I found a work around, not exactly a fix. I flashed the card back to my 4.01 image and scraped from there for a time. After rebooting I upgraded and now the scraper seems to work just fine. I can't say why that had an effect but it did so I'm good now. Thank you very much for the help.
                    • frankie842
                      frankie842 @dinkydinkypoo last edited by
                      @dinkydinkypoo Any updates on this? I don't want to re flash my card.
                      • frankie842
                        frankie842 @Michigen last edited by
                        @michigen Any luck getting this fixed?
                        Michigen 1 Reply Last reply Reply Quote 0
                        • Michigen
                          Michigen @frankie842 last edited by
                          @frankie842
                          Hey Buddy! I'm sorry. I was offline for a long time. Yeah I had an answer. Do you all ready fix it?
