    Unsolved slow, braking system
    slow braking
    6
    38
    17375
    • Edvis
      Edvis last edited by
      hello, why after the upgrade to 4.1 has become a strong brake system?
      In the spring, updated to 4.1 was the same, also slowed down.
        Humm I don't understand
        Edvis 1 Reply Last reply Reply Quote 1
        • Edvis
          Edvis @rockaddicted last edited by
          @rockaddicted music in the menu slowed and games began to work slower...
          if put the version below 4.1 then everything works well
            rockaddicted @Edvis last edited by
            @edvis hummm never add this kind of problem and you are the first one to report that.
            what is your configuration ? rpi version ? share on usb ? if usb, formated on which FS ?
            Edvis 5 Replies Last reply Reply Quote 1
            • Edvis
              @rockaddicted ok, a little later I will write
              • Edvis
                • Edvis
                  @rockaddicted RASPBERRY PI 3 model B v. 1.2
                  • Edvis
                    Edvis @rockaddicted last edited by paradadf
                    @rockaddicted
                    System Variable
                    You can configure your recalbox from here
                    To set a variable, remove the first ; on the line
                    ------------ A - System Options -----------
                    Uncomment the system.power.switch you use
                    ;system.power.switch=ATX_RASPI_R2_6 # http://lowpowerlab.com/atxraspi/#installation
                    ;system.power.switch=MAUSBERRY # http://mausberry-circuits.myshopify.com/pages/setup
                    ;system.power.switch=REMOTEPIBOARD_2003 # http://www.msldigital.com/pages/support-for-remotepi-board-2013
                    ;system.power.switch=REMOTEPIBOARD_2005 # http://www.msldigital.com/pages/support-for-remotepi-board-plus-2015
                    ;system.power.switch=WITTYPI # http://www.uugear.com/witty-pi-realtime-clock-power-management-for-raspberry-pi
                    ;system.power.switch=PIN56ONOFF # https://github.com/recalbox/recalbox-os/wiki/Add-a-start-stop-button-to-your-recalbox-(EN)
                    ;system.power.switch=PIN56PUSH # https://github.com/recalbox/recalbox-os/wiki/Add-a-start-stop-button-to-your-recalbox-(EN)
                    ;system.power.switch=PIN356ONOFFRESET # https://github.com/recalbox/recalbox-os/wiki/Add-a-start-stop-button-to-your-recalbox-(EN)
                    ;system.power.switch=PIN356PUSHRESET # https://github.com/recalbox/recalbox-os/wiki/Add-a-start-stop-button-to-your-recalbox-(EN)
                    fbcp FrameBuffer Copy Program
                    For small TFT screen on GPIO and SPI
                    See https://github.com/recalbox/recalbox-os/wiki/Utility---Use-of-fbcp-for-small-TFT-screen-(EN) for details
                    Needed for Waveshare 3.2" 3.5" TFT screen, 2.8" Adafruit screen
                    See https://github.com/recalbox/recalbox-os/wiki/TFT-Screen-SPI-Bus-(EN)
                    for support and configuration details needed by /boot/config.txt
                    system.fbcp.enabled=0
                    Recalbox Manager (http manager)
                    system.manager.enabled=1
                    1 or 2, depending on the manager version you wish
                    system.manager.version=2
                    Recalbox security
                    enforce security
                    samba password required
                    disable virtual gamepads
                    system.security.enabled=0
                    Recalbox API (REST)
                    system.api.enabled=1
                    Allow a specific resolution for ES only from the command : tvservice -m [MODE]
                    Leave commented for the default usual behaviour
                    ;system.es.videomode=CEA 4 HDMI
                    EmulationStation
                    menu style
                    default -> default all options menu
                    none -> no menu except the game search menu
                    bartop -> less menu, only needed for bartops
                    emulationstation.menu=default
                    Select a system to show on boot (use rom directory name) (string)
                    emulationstation.selectedsystem=favorites
                    Show the gamelist of the first or selected system on boot (0,1)
                    emulationstation.bootongamelist=0
                    Disable system view ES will boot and show ONLY the first or selected system (0,1)
                    emulationstation.hidesystemview=0
                    Pa**e Gamelists only. Show only games listed in gamelist.xml files (0,1)
                    emulationstation.gamelistonly=0
                    Force basicgameList view to be displayed, even if your game systems are scraped (0,1)
                    emulationstation.forcebasicgamelistview=0
                    Emulator special keys
                    default -> default all special keys
                    nomenu -> cannot popup the emulator menu
                    none -> no special keys in emulators
                    Show or hide kodi in emulationstation (0,1)
                    kodi.enabled=1
                    Start kodi at launch (0,1)
                    kodi.atstartup=0
                    set x button shortcut (0,1)
                    kodi.xbutton=1
                    Kodi can wait for a network component before starting
                    waithost is the ip or hostname that must answer to a ping to validate the availability
                    waittime is the maximum time waited when kodi boots
                    if waitmode is required, kodi will not start if the component is not available
                    if waitmode is wish, kodi will start if the component is not available
                    if waitmode is not set or has another value, kodi will start immediately
                    ;kodi.network.waittime=10
                    ------------ B - Network ------------
                    Set system hostname
                    system.hostname=RECALBOX
                    Activate wifi (0,1)
                    wifi.enabled=0
                    Wifi SSID (string)
                    ;wifi.ssid=new ssid
                    Wifi KEY (string)
                    after rebooting the recalbox, the "new key" is replace by a hidden value "enc:xxxxx"
                    you can edit the "enc:xxxxx" value to replace by a clear value, it will be updated again at the following reboot
                    Escape your special chars (# ; $) with a backslash : $ => $
                    ;wifi.key=new key
                    secondary wifi (not configurable via the user interface)
                    ;wifi2.ssid=new ssid
                    ;wifi2.key=new key
                    third wifi (not configurable via the user interface)
                    ;wifi3.ssid=new ssid
                    ;wifi3.key=new key
                    Samba share
                    system.samba.enabled=1
                    Virtual Gamepads
                    SSH
                    system.ssh.enabled=1
                    ------------ C - Audio ------------
                    Set the audio device (auto, hdmi, jack)
                    audio.device=jack
                    Set system volume (0..100)
                    audio.volume=79
                    Enable or disable system sounds in ES (0,1)
                    audio.bgmusic=1
                    -------------- D - Controllers -----------------
                    Enable support for standard bluetooth controllers
                    Please enable only one of these
                    -------------- D1 - PS3 Controllers ------------
                    controllers.ps3.enabled=1
                    Choose a driver between bluez, official and shanwan
                    bluez -> bluez 5 + kernel drivers, support official and shanwan sisaxis
                    official -> sixad drivers, support official and gasia sisaxis
                    shanwan -> shanwan drivers, support official and shanwan sisaxis
                    controllers.ps3.driver=bluez
                    ------------ D2 - GPIO Controllers ------------
                    GPIO Controllers
                    enable controllers on GPIO with mk_arcarde_joystick_rpi (0,1)
                    controllers.gpio.enabled=0
                    mk_gpio arguments, map=1 for one controller, map=1,2 for 2 (map=1,map=1,2)
                    controllers.gpio.args=map=1,2
                    DB9 Controllers
                    Enable DB9 drivers for atari, megadrive, amiga controllers (0,1)
                    controllers.db9.enabled=0
                    db9 arguments
                    controllers.db9.args=map=1
                    Gamecon controllers
                    Enable gamecon controllers, for nes, snes psx (0,1)
                    controllers.gamecon.enabled=0
                    gamecon_args
                    XGaming's XArcade Tankstik and other compatible devices
                    controllers.xarcade.enabled=1
                    ------------ F - Language and keyboard ------------
                    Set the language of the system (fr_FR,en_US,en_GB,de_DE,pt_BR,es_ES,it_IT,eu_ES,tr_TR,zh_CN)
                    system.language=ru_RU
                    set the keyboard layout (fr,en,de,us,es)
                    ;system.kblayout=us
                    Set you local time
                    Select your timezone from : ls /usr/share/zoneinfo/ (string)
                    ;system.timezone=Europe/Paris
                    ------------ G - UPDATES ------------
                    Automatically check for updates at start (0,1)
                    updates.enabled=0
                    Update type : default to stable
                    updates.type=stable
                    ------------ H - HERE IT IS - GLOBAL EMULATOR CONFIGURATION ------------
                    The global value will be used for all emulators, except if the value
                    is redefined in the emulator
                    Set game resolution for emulators
                    select your mode from the command : tvservice -m [MODE]
                    CEA 5 HDMI : 1920x1080 @ 60Hz 16:9, clock:74MHz interlaced
                    CEA 4 HDMI : 1280x720 @ 60Hz 16:9, clock:74MHz progressive
                    use 'default' for using the default resolution
                    (string)
                    global.videomode=default
                    Shader set
                    Automatically select shaders for all systems
                    ## (none, retro, scanlines)
                    global.shaderset=none
                    Once enabled, your screen will be cropped, and you will have a pixel perfect image (0,1)
                    global.integerscale=0
                    Set gpslp shader for all emulators (prefer shadersets above). Absolute path (string)
                    global.shaders=
                    Set ratio for all emulators (auto,4/3,16/9,16/10,custom)
                    global.ratio=4/3
                    Set smooth for all emulators (0,1)
                    global.smooth=0
                    Set rewind for all emulators (0,1)
                    global.rewind=0
                    Set autosave/load savestate for all emulators (0,1)
                    global.autosave=0
                    Enable retroarchievements (0,1)
                    Set your www.retroachievements.org username/password
                    global.retroachievements=0
                    global.retroachievements.hardcore=0
                    Set retroarch input driver (auto, udev, sdl2)
                    If you don't have issues with your controllers, let auto
                    global.inputdriver=auto
                    If you do not want recalboxOS to generate the configuration for all emulators (string)
                    ------------ I - EMULATORS CHOICES -----------
                    You can override the global configuration here
                    Here is the snes example
                    ;snes.videomode=CEA 4 HDMI
                    snes.core=snes9x_next
                    ;snes.ratio=16/9
                    snes.smooth=0
                    ;snes.rewind=1
                    ;snes.autosave=0
                    ;snes.emulator=libretro
                    ;snes.integerscale=0
                    If you do not want recalboxOS to generate the configuration for the emulator :
                    Default cores for RPi3
                    gba.core=mgba
                    mame.core=mame078
                    nes.core=fceumm
                    NeoGeo emulator
                    You can use pifba or a libretro core (fba2x,libretro)
                    neogeo.emulator=libretro
                    If you set libretro as neogeo.emulator, the line below sets the retroarch core (fba,imame4all)
                    neogeo.core=fba
                    N64 emulator is configured to display a screen with a 640x480 resolution (native n64 resolution)
                    So you must use one of these video modes (DMT 4 HDMI,CEA 1 HDMI).
                    If your screen is not compatible with one of these video modes, please check the recalbox's wiki.
                    n64.videomode=default
                    If you are using a CRT screen, please change the setting above with this one :
                    Dreamcast emulator
                    Like N64, such a CPU intensive emulator needs a small resolution
                    Consider DMT 4 HDMI (640480) or DMT 9 HDMI (800600). If you have a black screen on dreamcast, try DMT 9 HDMI here
                    dreamcast.videomode=DMT 4 HDMI
                    Configurations generated by Recalbox
                    system.es.menu=default
                    controllers.xboxdrv.enabled=0
                    gba.ratio=4/3
                    gba.smooth=0
                    megadrive.ratio=4/3
                    gbc.smooth=1
                    n64.smooth=1
                    n64.emulator=default
                    psx.smooth=1
                    • Edvis
                      @rockaddicted I remember in the spring, the first update to 4.1 worked well, and then it was updated and began to slow down everything
                        Substring @Edvis last edited by
                        @edvis as you're the only one having that problem, i believe the problem is just on your side. What class is your SD ? any overclock ? Does ithappen with a fresh install ?
                        Edvis 2 Replies Last reply Reply Quote 1
                        • Edvis
                          Edvis @Substring last edited by
                          @substring
                          on any overclock, micro sd sandisk ultra 32gb 10 class, with the new installation also slows down0_1508075753408_Screenshot_26.png
                            do you have a yellow "flash" icone on the top right of your screen ?
                            • Edvis
                              @rockaddicted no
                              • Edvis
                                @rockaddicted
                                does this micro sd fit?
                                  32gb ? nope it is ok.
                                  I really don't know.
                                  You roms are on USB or SD card ?
                                  The known issue about these kind of problems on a clean install are :
                                  • power supply issue (the yellow 'lightning" icone on top right of the screen)
                                  • bad sd card (chinese copy with bad transfer rate)
                                  • overclock unsupported on rpi
                                  I don't have any new ideas... @Substring and you ?
                                  Edvis 1 Reply Last reply Reply Quote 0
                                  • Edvis
                                    @rockaddicted
                                    without overclocking, the problem is the same.
                                    sd card is good. everything is on sd card.
                                    "overclock unsupported on rpi" what do you mean?
                                      @edvis each rpi react differently to overclock. Sometimes once enabled system become slow, unstable etc...
                                      • jeevuz
                                        jeevuz last edited by
                                        @Edvis Hi you use crt tv? I have the same problem onli in crt tv, hdmi works great.
                                        Edvis 2 Replies Last reply Reply Quote 0
                                        • Edvis
                                          Edvis @jeevuz last edited by
                                          @jeevuz hello, yes I use the crt TV, tired already to solve this problem.
                                          Also today I wanted to go to a friend to check whether it works on hdmi
                                          • Edvis
                                            @rockaddicted
                                            @jeevuz said in slow, braking system:
