    Bios while using external USB
    bios while external usb
    11542
    • kaz69
      kaz69 last edited by
      Hi All,
      I'm looking to use an external USB for all my roms, I have sorted out the USB stick and know where to place the ROMS but where im stuck is on the BIOS.
      1)Do I need to just drop the file into the BIOS folder or do I need to create a folder for that BIOS first as some have a number of files like Sega 32x?
      2)Do I need to rename some of my BIOS? as currently I have [BIOS] Atari Lynx (USA, Europe).lnx but some places are saying lynxboot.img?
      Thanks
      Substring abunille 2 Replies Last reply Reply Quote 0
        Substring @kaz69 last edited by
        @kaz69 Hi
        Have you erad the ******* manual ? https://github.com/recalbox/recalbox-os/wiki/Use-an-external-usb-storage-device-on-recalbox-(EN)
        kaz69 1 Reply Last reply Reply Quote 0
        • abunille
          abunille @kaz69 last edited by abunille
          @kaz69
          Hi,
          When you put an formatted usb device on your recalbox, go in system settings and chose this device. Then recalbox reboots and create "share" on your device.
          Put your roms then in "roms folder" and bios in "bios folder".
          1)https://github.com/recalbox/recalbox-os/wiki/Use-an-external-usb-storage-device-on-recalbox-%28EN%29
          2)https://github.com/recalbox/recalbox-os/wiki/Add-system-bios-%28EN%29
          • kaz69
            kaz69 @Substring last edited by
            @substring Hi, yes I went over the guide but I just need a specific answer to the questions which i cant find.
            @abunille thanks, I have downloaded the zip file for the Sega 32 but there are 7 .bin files do i just transfer all of them across in to the BIOS folder?
            regarding naming do i have to rename the file to the one on the list you had on the link?
            • abunille
              @kaz69
              How is written in the wiki.
              directly /recalbox/share/bios/
              I see only 3 files for that system in wiki.
              • kaz69
                kaz69 @abunille last edited by
                @abunille I think the first file number i search from the list had all the Bios in the list on plus more and that is what got me confused. i'll transfer all and see how it goes.
                thanks
                • abunille
                  @kaz69
                  If it works please mark this Topic as solved:
                  Press the three vertical squares on the right..
                  Topic Tools -> Ask a question + Topic Tools -> Mark as Solved
                  • kaz69
                    @abunille Thanks I do that
                    • kaz69
                      So have managed to get a number of BIOS across that work all ok, the one i'm having issues with is the Atari Lynx Bios as I have search for the one recommended in github but the only one that comes up is
                      I know lynxboot.img is needed so i changed the name but still the roms wont load.
                      when I load a game the screen goes black then back to the game selection screen.
                      abunille Substring 2 Replies Last reply Reply Quote 0
                      • abunille
                        @kaz69
                        Hi,
                        have you checked the "md5sum" how is written in the wiki?
                        When its not the md5sum you need, you must search further i think.
                        And have you checked your rom extension?
                        When they are .zip files, look into the .zip, if the file inside is an supported extension.
                        kaz69 2 Replies Last reply Reply Quote 0
                        • kaz69
                          @abunille
                          Thanks, let me get on this and see how I go
                          • kaz69
                            @abunille
                            i checked the file extension with the read me file in the Lynx folder and i'm using a .lnx file.
                            im checking the md5sum tonight as been having some laptop issues
                              @kaz69 Is your problem with the lynx bios or lynx roms themselves ? The current core doesn't support the no-intro file format
                              • kaz69
                                checked BIOS on md5sum and it matches the one on github.
                                @Substring I'm not sure which as the BIOS number matches up right and the Roms are correct for whats said in the read me file .lnx Whats he no-intro file format?
                                  @kaz69 the lynx emulator is quite a pain, it doesn't accept whichever rom ...
                                  • kaz69
                                    i downloaded the roms from a trusted site and all their other roms are fine, maybe its just lynx
                                      @kaz69 as I said, the emulator is very picky on roms and doesn't support the widespread rom headers (some crap like that)
                                      • kaz69
                                        @substring thanks I guess it's just trying out different games and seeing what works and doesn't.
                                        Do you know what other emulators are like this so I'm prepared for it 😊
                                          @kaz69 well, dunno if you tried arcade yet ...
                                          • kaz69
                                            @substring
                                            Yeah tried arcade and got a few working on FBA libretro that didn't work on MAME but I'm still trying to get the Michael Jackson Arcade game to work.
                                            Lynx I'm still working on but fingers crossed I'll find something, then I can post my findings here
