    Solved Wired Xbox 360 controller not working
    GamePad/GPIO/USB encoder
    wired xbox 360
    • kaz69
      kaz69 last edited by
      Hi
      I have the official Xbox 360 controller and have it wired by the charging cable to my PI USB. The controller is detected in the config section but won't config when I hold the button down, the lights keep flashing on the control but doesn't stay on or to one indicating player 1 selected.
      Is it the charging cable that's the problem and won't work so then I would need the wireless receiver?
      I have made the xboxdrv xhanges
      Thanks
      • kaz69
        Managed to sort it myself
        The charging cable doesn't work like it does on the Xbox it has to be a fully wired controller or using a wireless receiver which I went for and works straight out the box
