    Confirmed: PSP's FuSa Gamepad works flawlessly
    GamePad/GPIO/USB encoder
    psp fusa gamepad gamepadhow recalbox4
    3500
    • sergioad
      sergioad last edited by
      Hi friends I came here to broudly report that the PSP homebrew for PSP model 1,000 2,000 and 3,000 with custom firmware called called FuSa Gamepad is completely usable with Recalbox 4.0.2 and works flawlessly, to use it you need your PSP with a CFW, a male USB type A to male Miniusb type B (5 pin MiniUSB) cable and FuSa gamepad
        rockaddicted @sergioad last edited by
        @sergioad nice, thank you for this report.
        I'll test that today for fun 😉
          indeed works pretty well, I'll add the default mapping in recalbox 4.1.
          sergioad 1 Reply Last reply Reply Quote 0
          • sergioad
            sergioad @rockaddicted last edited by sergioad
            @rockaddicted Ok, my recomendation is to use the Japanese PS style (wich is a copy of the SNES layout) and you still have the home and screen buttons mapable
            • sergioad
              As you may see, while I have an XBOX 360 gamepad I am highly investing on the SNES layout since I have a PSP, a generic USB SNES gamepad and even I am saving money to get a beutyfull slick Pokken pad for Wii U wich is basicaly a SNES controller with handles and two extra buttons so, if you can add a checkbox in the recalbox menu's input screen to swap the accept and back buttons (wich I know it is a low priority goal in your To-Do list) I will thank you a lot 😀
              • sergioad
                sergioad @sergioad last edited by
                If I get it and see that it works I will inmediatly inform you
                  voljega Banned @sergioad last edited by
                  @sergioad someone already tested it, it works
                  • sergioad
                    sergioad @voljega last edited by
                    @voljega Ok
