    Prob with atariSt roms
    Your recalbox
    prob atarist roms
    5975
    • gothrek
      gothrek last edited by
      Hi guys, i try to found the same error in the forum, but i dont found something about this.
      i use a recalbox 4.02 with a atarist bios 1.02 uk (the check about md5 is ok) and put the romms in the folder, recalbox found 305 roms.
      every, i try all 305 roms, give me back this error:
      this version of Hatari was build w...
      support, this disk image cant' be hand...
      i see only the left part of the error.
      Can u help me?
      tks
        voljega Banned @gothrek last edited by voljega
        @gothrek contrary to what is said in the readme.txt file, atari st emulator supports only .st roms, not .stx if that is your problem...
        • gothrek
          i insert only .zipfile, i need to explode all? the recalbox show me all roms name and i can select all but when start i receive the error
            the problem with zip files is that format is seen and displayed by emulationstaiton. But you don't know what kind of file you have inside.
            So if your archive include a not supported file type, emulator won't be able to start the game.
            gothrek 1 Reply Last reply Reply Quote 0
            • gothrek
              gothrek @rockaddicted last edited by
              @rockaddicted hi, i put all zip file, i can see the list in recal box and the scraper. when i select a game, i receive this error (with a mouse cursor, i can use the mouse for click ok and close the error window)
                Unzip your files if .ipf files it is only supported since 4.1 release
                • gothrek
                  @rockaddicted ok, i explode all roms now i have file .ipf i try these files and give u a feedback. For the .zip i read into teadme.txt and i dont understand that works only from 4.1.
                  give me some minutes and give u a feedback about ,ipf file
                    Because I had to patch the emulator to allow .ipf files support, and I did it on 4.1
                    So download some new ROMs, in the good format referring to readme.txt file.
                    • gothrek
                      @rockaddicted well a bit better, now i have a black and white atari screen and if a press a key i have an hatari main menu for conf hard disk floppy and other things. i can use the mouse. its normal this menu?
                      tks
                        download roms on .st format -> https://github.com/recalbox/recalbox-buildroot/blob/rb-4.0.X/board/recalbox/fsoverlay/recalbox/share_init/roms/atarist/_readme.txt#L5
                        then once ingame here is the emulator mapping (snes style)
                        https://github.com/recalbox/recalbox-os/wiki/ATARI-ST-(EN)
                        gothrek 1 Reply Last reply Reply Quote 1
                        • gothrek
                          @rockaddicted perfect, now .st and .stx roms start. i have a very bad sound but i try to solve this alone, thank a lot man!!
