    So what about bin.ecm and .ape files psx?
    bin.ecm ape
    • filledk
      filledk last edited by
      Hey all, I'm trying to get recalbox and psx emulator to rub psx games, I have downloaded a rom, that is a .zip file, in side this zip file there is a 7zip file (which contain the .bin.ecm file) and a bunch of .ape files...
      How do I get it to play on the recalbox PSX emulator?
      • NeeeeB
        NeeeeB last edited by NeeeeB
        If I remember correctly PSX emulators only supports zip, iso, cue, bin files.
        So I think your rom is not in the good format.
        Did you try to leave the zip file as is and run it ?
        Vieux geek ^^
          voljega Banned @filledk last edited by
          @filledk you have to decompress that to get you bin and cue it'e pretty esay to find documenation for this
          • Pixelboy
            Pixelboy last edited by Pixelboy
            hello!
            extract the 7.zip file, then exctract the bin.ecm inside, download ecm100, take the .bin.ecm and drag it onto the unecm.exe, it will decompress it and you will have a .bin file, join it with the .cue in the first zip file.
            • msilver
              msilver last edited by
              hello, Excuse my english. I converted the file so and created a * .cue, but unfortunately there are sound problems when playing. it's rushing.
