    Manette PS4
    ps4
    11933
    • Treize
      Treize last edited by
      Excuse moi si je me trompe, je pensais l'avoir bien uploadé dans mon post précédent celui d'@acris .
      Je me suis trompé où dans la manœuvre ?
      • Treize
        Ah ! Si j'oublie de faire en sorte que tu sois notifié :s
        @Substring Ce n'est pas cela que tu veux : http://www43.zippyshare.com/v/LaXUqAYy/file.html ?
          Substring @Treize last edited by
          @Treize donc dans les logs je lis un truc bizarre :
          Jun 25 11:20:06 RECALBOX user.info kernel: [ 1275.891040] usb 1-1.4: new full-speed USB device number 10 using dwc_otg
          Jun 25 11:20:06 RECALBOX user.info kernel: [ 1275.994042] usb 1-1.4: New USB device found, idVendor=054c, idProduct=05c4
          Jun 25 11:20:06 RECALBOX user.info kernel: [ 1275.994058] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
          Jun 25 11:20:06 RECALBOX user.info kernel: [ 1275.994065] usb 1-1.4: Product: Wireless Controller
          Jun 25 11:20:06 RECALBOX user.info kernel: [ 1275.994071] usb 1-1.4: Manufacturer: Sony Computer Entertainment
          Jun 25 11:20:06 RECALBOX user.info kernel: [ 1275.996517] sony 0003:054C:05C4.0008: Using modified Dualshock 4 report descriptor with gyroscope axes
          Jun 25 11:20:06 RECALBOX user.info kernel: [ 1276.012879] input: Sony Computer Entertainment Wireless Controller as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.0/0003:054C:05C4.0008/input/input7
          Jun 25 11:20:06 RECALBOX user.info kernel: [ 1276.013352] sony 0003:054C:05C4.0008: input,hidraw0: USB HID v1.11 Gamepad [Sony Computer Entertainment Wireless Controller] on usb-3f980000.usb-1.4/input0
          Jun 25 11:20:25 RECALBOX daemon.err bluetoothd[1438]: Can't get HIDP connection info
          Mais aussi
          Jun 25 11:16:15 RECALBOX daemon.info bluetoothd[1409]: Bluetooth daemon 5.39
          Jun 25 11:16:15 RECALBOX daemon.warn bluetoothd[1409]: Unknown key PageTimeout in main.conf
          Jun 25 11:16:15 RECALBOX daemon.warn bluetoothd[1409]: Unknown key InitiallyPowered in main.conf
          Jun 25 11:16:15 RECALBOX daemon.warn bluetoothd[1409]: Unknown key RememberPowered in main.conf
          Jun 25 11:16:15 RECALBOX daemon.warn bluetoothd[1409]: Unknown key EnableGatt in main.conf
          Jun 25 11:16:16 RECALBOX daemon.info bluetoothd[1409]: Starting SDP server
          Jun 25 11:16:16 RECALBOX daemon.info bluetoothd[1409]: Bluetooth management interface 1.10 initialized
          Jun 25 11:16:16 RECALBOX daemon.err bluetoothd[1409]: Failed to obtain handles for "Service Changed" characteristic
          Jun 25 11:19:51 RECALBOX daemon.info bluetoothd[1409]: Terminating
          Jun 25 11:19:51 RECALBOX daemon.info bluetoothd[1409]: Stopping SDP server
          Jun 25 11:19:51 RECALBOX daemon.info bluetoothd[1409]: Exit
          2 choses : de mémoire il n'y a pas de main.conf dans recalbox pour bluez5
          L'autre truc c'est lorsque bluez interroge ton pad et ne parvient pas à avoir des descripteurs HIDP ... Pourquoi branches-tu ton pad PS4 en USB ???
          • Treize
            Salut @Substring,
            Pour le main.conf, comment vérifier ça ?
            Et pour le pad ps4 en usb c'est tout simplement que je navigue avec une manette en usb tandis que je test le bth de l'autre.
              @Treize j'aimerais autant que tu utilises autre chose que du ps4 en usb, je vais finir chèvre sinon 😄
              Tes pads sont ils à jour ? Pas eu le temps de regarder cette histoire de main.conf ... Tu es sur une maj 4.0->4.1 ou tu es parti d'une image ?
              • Treize
                @Substring Haha 😄 Pas de problème je vais essayer de trouver autre chose.
                Tout est à jour, je suis sur une màj 4.0->4.1.
                  @Treize mmhhh ca expliquerait les pb avec le main.conf cette maj 4.0 -> 4.1. Malheureusement j'ai tellement peu de temps pour mio en ce moment, tout juste le temps de répondre au fofo
                  100.3k
