    NTP never syncs
    ntp never syncs
    • kube
      kube last edited by
      I'm running V4.1.0-DEV and NTP doesn't seem to want to sync. I've tried killing the service and running it manually with ntpd -gxq4 and it prints out the following, then just sits there forever.
       1 Jan 01:40:49 ntpd[1220]: ntpd 4.2.8p8@1.3265-o Thu Apr 27 13:08:26 UTC 2017 (1): Starting
       1 Jan 01:40:49 ntpd[1220]: Command line: ntpd -gxq4
       1 Jan 01:40:49 ntpd[1220]: proto: precision = 0.833 usec (-20)
       1 Jan 01:40:49 ntpd[1220]: restrict: ignoring line 11, address/host '[::1]' unusable.
       1 Jan 01:40:49 ntpd[1220]: Listen and drop on 0 v4wildcard 0.0.0.0:123
       1 Jan 01:40:49 ntpd[1220]: Listen normally on 1 lo 127.0.0.1:123
       1 Jan 01:40:49 ntpd[1220]: Listen normally on 2 wlan0 192.168.0.123:123
       1 Jan 01:40:49 ntpd[1220]: Listening on routing socket on fd #19 for interface updates
      Other relevant info:
      # cat /etc/ntp.conf
      server 0.ca.pool.ntp.org iburst
      server 1.ca.pool.ntp.org iburst
      server 2.ca.pool.ntp.org iburst
      server 3.ca.pool.ntp.org iburst
      restrict default nomodify nopeer noquery limited kod
      restrict 127.0.0.1
      restrict [::1]
      # ping -c3 0.ca.pool.ntp.org
      PING 0.ca.pool.ntp.org (198.245.51.213): 56 data bytes
      64 bytes from 198.245.51.213: seq=0 ttl=56 time=29.441 ms
      64 bytes from 198.245.51.213: seq=1 ttl=56 time=37.053 ms
      64 bytes from 198.245.51.213: seq=2 ttl=56 time=33.911 ms
      --- 0.ca.pool.ntp.org ping statistics ---
      3 packets transmitted, 3 packets received, 0% packet loss
      round-trip min/avg/max = 29.441/33.468/37.053 ms
      Any help is appreciated.
      100.8k
