    Ps3 usb ne fonctionne pas
    ps3 usb
    • technobro
      technobro last edited by
      Bonjour a tous. félicitation pour le beau projet Je n'arrive pas à syncronisé ma manette ps3 usb. je ne veux pas l'utilisé bluetooth j'ai tenté de la resetter . ca semble etre un prob de driver voici les logs de /var/log/messages May 23 19:00:35 RECALBOX user.info kernel: [ 1212.833793] usb 1-1.2: new full-speed USB device number 9 using dwc_otg May 23 19:00:36 RECALBOX user.info kernel: [ 1213.484068] usb 1-1.2: New USB device found, idVendor=054c, idProduct=0268 May 23 19:00:36 RECALBOX user.info kernel: [ 1213.484110] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0 May 23 19:00:36 RECALBOX user.info kernel: [ 1213.484128] usb 1-1.2: Product: PLAYSTATION(R)3 Controller May 23 19:00:36 RECALBOX user.info kernel: [ 1213.484143] usb 1-1.2: Manufacturer: Sony May 23 19:00:36 RECALBOX user.info kernel: [ 1213.576353] sony 0003:054C:0268.0006: Fixing up Sony Sixaxis report descriptor May 23 19:00:36 RECALBOX user.info kernel: [ 1213.803078] input: Sony PLAYSTATION(R)3 Controller as /devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2:1.0/input/input4 May 23 19:00:36 RECALBOX user.info kernel: [ 1213.807311] sony 0003:054C:0268.0006: input,hiddev0,hidraw1: USB HID v1.11 Joystick [Sony PLAYSTATION(R)3 Controller] on usb-bcm2708_usb-1.2/input0 May 23 19:00:36 RECALBOX daemon.info bluetoothd[570]: Bluetooth daemon 4.101 May 23 19:00:36 RECALBOX daemon.info bluetoothd[572]: Starting SDP server May 23 19:00:36 RECALBOX daemon.err bluetoothd[572]: DIS cannot start: GATT is disabled May 23 19:00:36 RECALBOX daemon.err bluetoothd[572]: Failed to init deviceinfo plugin May 23 19:00:36 RECALBOX daemon.err bluetoothd[572]: Failed to init proximity plugin May 23 19:00:36 RECALBOX daemon.err bluetoothd[572]: Failed to init time plugin May 23 19:00:36 RECALBOX daemon.err bluetoothd[572]: Failed to init alert plugin May 23 19:00:36 RECALBOX daemon.err bluetoothd[572]: Failed to init thermometer plugin May 23 19:00:36 RECALBOX daemon.err bluetoothd[572]: Failed to open control socket: Protocol not supported (93) May 23 19:00:36 RECALBOX daemon.err bluetoothd[572]: Can't init bnep module May 23 19:00:36 RECALBOX daemon.err bluetoothd[572]: Failed to init network plugin May 23 19:00:36 RECALBOX daemon.err bluetoothd[572]: Parsing /etc/bluetooth/input.conf failed: No such file or directory May 23 19:00:36 RECALBOX daemon.err bluetoothd[572]: Parsing /etc/bluetooth/audio.conf failed: No such file or directory May 23 19:00:36 RECALBOX daemon.err bluetoothd[572]: Failed to init gatt_example plugin May 23 19:00:36 RECALBOX daemon.info bluetoothd[572]: Bluetooth Management interface initialized May 23 19:00:36 RECALBOX daemon.err bluetoothd[572]: Failed to open RFKILL control device May 23 19:00:39 RECALBOX daemon.info bluetoothd[572]: Terminating May 23 19:00:39 RECALBOX daemon.info bluetoothd[572]: Stopping SDP server May 23 19:00:39 RECALBOX daemon.info bluetoothd[572]: Exit je n'arrive pas à faire de test avec  jstest /dev/input/js0 puise qu'il n'y a pas de js0 je suis ouvert à testé ... merci à l'avance Edit: j'ai oublié de dire la manette flashe toujours
      • n1kod
        n1kod last edited by
        ta manette fonctionne en usb ? regarde les posts récent, apparemment le modèle "US" de cette manette ne fonctionne pas avec recalcbox pour le moment
        Rpi2 + microsd 16go Manettes : Buffalo snes usb Boitier : NES + mausberry circuit Alimentation : belkin 2A
