    Edit es_system.cfg for PS1 games?
    edit essystem.cfg ps1
    • opossum
      opossum last edited by
      Hi, I'm trying to configure the ps1 emulator to show only the cue files in ES so I won't end up with duplicate files when I have a game with multiple bin files...
      As far as i know it's necessary to edit:
      <fullname>Sony Playstation 1</fullname>
      <name>psx</name>
      <path>/recalbox/share/roms/psx</path>
      <extension>.img .IMG .pbp .PBP .bin .BIN .cue .CUE .iso .ISO .ccd .CCD</extension>
      in
      /recalbox/share_init/system/.emulationstation/es_systems.cfg
      I obtained permissions entering Pi with PuTTy software using command:
      mount -o remount,rw /
      After this I edited es_system.cfg entering the file with WinSCP and changing the string to:
      <extension>.cue .CUE .cbn .CBN .img .IMG .mdf .MDF .pbp .PBP .toc .TOC .z .Z .znx .ZNX</extension>
      and saved... Now, with this little change EmulationStation wasn't booting anymore (error message), and I had to change again the string to default to make it run again...
      Where is the mistake? Please let me know!
      Thanks.
      A.
        voljega Banned @opossum last edited by
        @opossum said in Edit es_system.cfg for PS1 games?:
        never heard of those format for psx games and I doubt they're supported...
        you must have made a mistake not closing correctly the tag extension or something, redo it
        also if you're on windows, only use notepad++ or your end of lines characters will be broken... you could also have copied a windows end of line character at the end of </extension> without realizing it
        • opossum
          Solved... Always use notepad++ 🙂
          101.4k
