    Solved Fba reste en 16/9
    fba reste 169
    8708
    • Fabeer
      Fabeer last edited by
      Bonjour a tous,
      j'ai un soucis avec Fba,qui reste desesperement en 16/9 bien que j'ai changé les options sous le menu de presentation,4/3 pour tout les emulateurs...
      Raspberry pi 3
      version 4.0.2
      roms sur disque dur externe
      joystick hori fightstick ex2
      Merci pour votre aide
        Substring @Fabeer last edited by
        @Fabeer Bonjour
        Tu peux faire un pastebin de ton recalbox.conf stp ?
        • Fabeer
          Fabeer last edited by acris
          @Substring
          Here it is!
          # System Variable
          system.manager.enabled=1
          ## Recalbox API (REST)
          system.api.enabled=0
          ## EmulationStation menu style
          ## default -> default all options menu
          ## none -> no menu except the game search menu
          ## bartop -> less menu, only needed for bartops
          system.es.menu=default
          ## Emulator special keys
          kodi.enabled=1
          ## Start kodi at launch (0,1)
          kodi.atstartup=0
          kodi.xbutton=1
          ;kodi.network.waittime=10
          ## Set system hostname
          system.hostname=RECALBOX
          ## Activate wifi (0,1)
          wifi.enabled=1
          ## Wifi SSID (string)
          wifi.ssid=SfrFab
          ## Wifi KEY (string)
          wifi.key=??????
          ## Samba share
          system.samba.enabled=1
          ### Virtual Gamepads
          ### SSH
          system.ssh.enabled=1
          audio.device=auto
          ## Set system volume (0..100)
          audio.volume=90
          audio.bgmusic=1
          controllers.ps3.enabled=1
          ## Choose an driver between official, shanwan and gasia if you have dualshock clones (official,shanwan,gasia)
          controllers.xboxdrv.enabled=0
          ## GPIO Controllers
          controllers.gpio.enabled=0
          controllers.gpio.args=map=1,2
          ## DB9 Controllers
          controllers.db9.enabled=0
          ## db9 arguments
          controllers.db9.args=map=1
          ## Gamecon controllers
          controllers.gamecon.enabled=0
          ## gamecon_args
          controllers.xarcade.enabled=1
          system.language=fr_FR
          ;system.kblayout=us
          ## Set you local time
          ;system.timezone=Europe/Paris
          updates.enabled=1
          # Update type : default to stable
          # set to unstable at your own risk to get the development version.
          updates.type=stable
          ## (string)
          global.videomode=CEA 4 HDMI
          ## Shader set
          ## (none, retro, scanlines)
          global.shaderset=scanlines
          global.integerscale=1
          global.shaders=
          global.ratio=4/3
          global.smooth=0
          global.rewind=0
          global.autosave=0
          global.retroachievements=0
          global.inputdriver=auto
          ## Here is the snes example
          ;snes.videomode=CEA 4 HDMI
          snes.core=snes9x_next
          snes.ratio=4/3
          ;snes.smooth=0
          ;snes.rewind=1
          ;snes.autosave=0
          ;snes.emulator=libretro
          ;snes.integerscale=0
          ## Default cores for RPi3
          gba.core=mgba
          mame.core=mame078
          nes.core=fceunext
          ## NeoGeo emulator
          neogeo.emulator=libretro
          ## If you set libretro as neogeo.emulator, the line below sets the retroarch core (fba,imame4all)
          neogeo.core=fba
          n64.videomode=DMT 4 HDMI
          # n64.videomode=default
          fba.ratio=4/3
          nes.ratio=4/3
          n64.ratio=4/3
          gba.ratio=4/3
          gbc.ratio=4/3
          gb.ratio=4/3
          virtualboy.ratio=4/3
          megadrive.ratio=4/3
          segacd.ratio=4/3
          sega32x.ratio=4/3
          mastersystem.ratio=4/3
          gamegear.ratio=4/3
          sg1000.ratio=4/3
          psx.ratio=4/3
          pcengine.ratio=4/3
          pcenginecd.ratio=4/3
          supergrafx.ratio=4/3
          fba_libretro.ratio=4/3
          mame.ratio=4/3
          neogeo.ratio=4/3
          atari7800.ratio=4/3
          lynx.ratio=4/3
          ngpc.ratio=4/3
          prboom.ratio=4/3
          vectrex.ratio=4/3
          fba.emulator=fba2x
            ouh là ouh là ouh là ...
            Tu vas éditer ton recalbox.conf et me virer
            fba.ratio=4/3
            nes.ratio=4/3
            n64.ratio=4/3
            gba.ratio=4/3
            gbc.ratio=4/3
            gb.ratio=4/3
            megadrive.ratio=4/3
            segacd.ratio=4/3
            sega32x.ratio=4/3
            gamegear.ratio=4/3
            sg1000.ratio=4/3
            psx.ratio=4/3
            pcengine.ratio=4/3
            mame.ratio=4/3
            neogeo.ratio=4/3
            atari7800.ratio=4/3
            lynx.ratio=4/3
            ngpc.ratio=4/3
            prboom.ratio=4/3
            vectrex.ratio=4/3
            fba.emulator=fba2x
            Tu as changé l'émulateur par défaut de FBA, notamment.
            • Fabeer
              c'est viré,rebooté
              et toujours pareil
              # System Variable
              kodi.enabled=1
              kodi.atstartup=0
              kodi.xbutton=1
              wifi.enabled=1
              wifi.ssid=SfrFab
              wifi.key=mas30descattes30
              ## Samba share
              ### SSH
              audio.device=auto
              audio.volume=90
              audio.bgmusic=1
              ## GPIO Controllers
              ## DB9 Controllers
              ## db9 arguments
              ## gamecon_args
              ;system.kblayout=us
              updates.enabled=1
              updates.type=stable
              ## (string)
              ## Shader set
              global.shaders=
              global.ratio=4/3
              global.smooth=0
              global.rewind=0
              global.autosave=0
              snes.ratio=4/3
              ;snes.smooth=0
              ;snes.rewind=1
              ;snes.autosave=0
              gba.core=mgba
              mame.core=mame078
              nes.core=fceunext
              ## NeoGeo emulator
              neogeo.core=fba
              Fabeer 1 Reply Last reply Reply Quote 0
              • Fabeer
                Fabeer @Fabeer last edited by
                @Substring
                  @Fabeer tu peux détailler ton moniteur ?
                  • Fabeer
                    Fabeer last edited by Fabeer
                    @Substring
                    il s'agit d'un televiseur philips de 37 pouces,full hd
                    tout les autres emulateurs passent bien en 4/3 sauf fba
                      Fba = pifba
                      Fba libretro = core utilisable avec retroarch.
                      Lequel utilises tu vraiment ?
                      • Fabeer
                        Fabeer @acris last edited by
                        @acris said in Fba reste en 16/9:
                        Fba = pifba
                        Il s'agit de pifba, Fba libretro bascule bien en 4/3 lui
                          @Fabeer
                          La gestion dun emulateur standaline nest pas la.meme avec un core libretro utilisant retroarch.
                          Il a son propre fichier de config.
                          • Fabeer
                            @acris Et quelle est donc la solution pour basculer en 4/3,si il y en a une...?
                              Il faudra aller à la peche aux infos sur le site pifba.
                              Le fichier de config se trouve dans /recalbox/share/system/configs/fba
                              Peut etre modifier l option
                              MaintainAspectRatio=1
                              A moins que @Substring est prevu la gestion dans recalbox.conf
                              Bien sur avec un rpi3 nous te conseillerons l utilisation fba libretro qui est plus complet et récent que pifba.
                                Ya aussi ce sujet sur pifba et le 16/9
                                https://forum.recalbox.com/topic/1332/pifba-et-pifba-libreto/3
                                • Fabeer
                                  Merci pour vos conseils,j'ai migré sur fba libretro,ca tourne nickel
                                    Substring @acris last edited by
                                    @acris mmhhhhh ca devrait être par défaut ca surtout sur pifba ...
                                      @Substring qu est qui devrait etre par defaut ?
                                        @acris l'option que tu as indiquée
                                          Oui l option indiqué est celle par défaut mais apparemment donne un ration 16/9 donc c est surement ce paramètre qu'il aurait fallu tester sans doute
                                          mais apparemment cest normal et ok d apres gkralicek et ça dépend des jeux.
                                          Autant utiliser fba libretro sur un rpi3
                                          En fait le problème de "16/9" que tu mentionnes avec PiFBA ne se pose qu'avec les jeux Capcom (Street Fighter II / Alpha, Marvel vs Capcom, SNK vs Capcom et autres). Si tu lances un Metal Slug ou autres jeux non-Capcom le ratio 4/3 est bien respecté. En fait cela vient de la résolution native des jeux Capcom qui est de 384 * 224 (soit un ratio de 1.71 donc assez proche du ratio 1.77 du 16/9). PiFBA ne fait que respecter le ratio original du jeu ce qui te donne l'impression (justifiée) de le voir affiché en 16/9 avec bandes noires en haut et en bas. Le souci c'est que l'image affichée comme çà donne l'impression que les personnages ont "épaissis" en largeur 🙂 et ce n'est pas très beau (à mon goût en tous cas). Idem pour les jeux verticaux de Capcom comme Dimahoo ou on se retrouve, une fois l'image passée en vertical, avec une zone d'affichage de 224 * 384 occupant une toute petite partie de l'écran au centre avec deux énormes bandes noires à gauche et à droite ce qui donne l'impression que les objets sont compressés et étirés dans le sens de la hauteur (les cercles ont l'air d'ellipses). Capcom développait ses jeux dans cette résolution mais anamorphosait les sprites de manière à ce qu'ils retrouvent leur forme correcte une fois l'image affichée sur toute la surface d'un écran 4/3 de borne d'arcade. L'astuce que j'utilise pour afficher l'image avec des dimensions correctes sur la totalité de la dalle 4/3 sous PiFBA consiste à choisir "16/9" comme format d'image dans les menus système de Recalbox. Les jeux 4/3 seront toujours affichés en 4/3 et les jeux avec un format particulier proche du 16/9 seront affichés sur toute la hauteur de l'écran 4/3. Malheureusement cela ne fonctionne qu'avec les jeux horizontaux (pour les jeux verticaux Capcom, je m'abstiens tout simplement de les faire tourner sous PiFBA et passe alors sous FBA Libretro :))
                                          smashboy2000 1 Reply Last reply Reply Quote 0
                                          • smashboy2000
                                            smashboy2000 @acris last edited by
                                            @acris J'ai le même soucis mais les jeux ne fonctionnent simplement pas sous fba libretro.
                                            Obligé de les lancer avec "fba" tout court, et donc de les avoir étirés.
                                            Je sais que le sujet date d'il y a deux ans mais personne n'a trouvé une solution depuis ?
