    Xu4 + cloudshell case + Display
    xu4 cloudshell case display
    • pillemats
      pillemats last edited by
      Hey there
      I have the xu4 and the cloudshell case with the Display. Is it possible to activate and use the Display ? Maybe for temperature or space from the hdd ?
      How can i get this to run ?
      I am searching a lot of time here an also in Web but i can not find anything....
      pillemats 1 Reply Last reply Reply Quote 0
      • pillemats
        pillemats @pillemats last edited by
        es gibt anscheinend diesen befehl den ich über root eingeben kann um das display zu aktivieren
        apt-get install odroid-cloudshell
        allerdings kommt dann das hier
        -sh: apt-get: command not found
        was bedeutet das ? und wie kann ich es beheben ?
        • pillemats
          Can anyone help ne please?
          I have found the xorg but i dont know how i can use that !
          If i have understand it right it is a mirroring from hdmi to the internal cloud display
