    Solved Qualità grafica PSX
    Italiano
    qualità grafica
    5274
    • Enrico Rossetto
      Enrico Rossetto last edited by
      Scusate, questa è solo una domanda di curiosità. Ma è possibile che la grafica dei giochi PSX sia un po' più scadente rispetto agli "originali"? Ho provato "Twisted Metal" e "Twisted Metal 2". Più che altro volevo capire se è un "problema" di compatibilità di alcuni giochi o della mia "postazione" (rpi3 con un TV 55"). Ho provato a cambiare emulator (default -> libretro), ma sembra che non ci sia differenza apprezzabile.
      Hi there! Another question about PSX games: I played "Twisted Metal" and "Twisted Metal 2" and it seems that the graphic quality can't be compared with that of the same game played on the console (sorry for my english). Is it just a compatibility of the specific game with the psx-emulator? I play wiath a rpi3 on a 55" Led TV. Tried to alternate the default emulator with libretro without noticing any differences.
        voljega Banned @Enrico Rossetto last edited by
        @Enrico-Rossetto
        many people have the same feeling and the answer is always the same :
        if you compare with your memories of the same game played on the console rather than really with the same game played on the console, check your memories 🙂
        psx games were ugly, but old tvs masked a little bit of the ugliness
        Enrico Rossetto 1 Reply Last reply Reply Quote 0
        • Enrico Rossetto
          Enrico Rossetto @voljega last edited by
          @voljega thanks, I had the same feeling, but my wife didn't! 😉 Then i doubted of my feelings because while scraping psx games I saw good pictures!
          Thank you and sorry about the dumb question 😉
            @Enrico-Rossetto no prob, everyone is dumbfounded by that one, first 3d games were such a novelty that we totally forgot how the first ones were ugly !
            • azvarel
              azvarel last edited by
              @Enrico-Rossetto
              A game that enjoyed a lot of the psx was medievil, but if you watch the graphics it gives you disgust. But it's still fun.
              Road rash even is a super rough graphics, but it's also fun, it's all about our memory and look like I was enjoying 3DO more (laughs)
              Try using the shaders, scanlines to see what your memory approaches, even though I hate it.
              Another detail: the larger the TV, the greater the pixelization, although by default the majority runs at 720p (bursting)
              Zodian Theme | #SNESProject
              • Enrico Rossetto
                Enrico Rossetto @azvarel last edited by
                @azvarel Thank you. It is maybe possible to run games at a lower resolution or perhaps a "windowed mode" (to use a "pc" definition)? Personally I enjoy Megadrive/Genesis games a lot (my first love) and they look pretty good even by hig resolution. My wife loves the Resident Evil saga very much (and Twisted Metal too), so I started collecting PSX games in recalbox 😉
                  voljega Banned @Enrico Rossetto last edited by voljega
                  @Enrico-Rossetto I forgot to mention that there's a core parameter for psx in retroarch called enhanced resolution which.... wait for it.... enhances resolution ! But on Pi3 without overclocking, games are then lagging... maybe it works better on 4.1 with overclocking.
                  PSX is the only console for which I totally deactivated shaders & scanlines it's better without it
                  Enrico Rossetto 2 Replies Last reply Reply Quote 0
                  • Enrico Rossetto
                    @voljega so I have to wait the next release 😉 Why is overclocking in Pi3 disabled?
                      @Enrico-Rossetto It's not disabled it wasn't available through the menu yet.
                      It was available because the Pi3 heat goes up a lot more than pi2 and so overclocking is ore unstable and random than on previous model....
                      • Enrico Rossetto
                        @voljega RPi3 is a hot guy 😉 I bought an aluminium case with 2 heath sinks but cannot go under 53 celsius with kodi in standby... Bought a RPi3 because of the better dreamcast compatibility 😉
                        • Enrico Rossetto
                          Where i can find this parameter?
                          @voljega said in Qualità grafica PSX:
                            @Enrico-Rossetto in retroarch core options for psx
                            • Enrico Rossetto
                              @voljega If I understand: start a PSX game, then open the retroarch option and modify the parameter. This change then is applied for all psx game
                                @Enrico-Rossetto yes for core options... but you'll see that games are lagging after that so you 'll likely turn it off like me
                                101.0k
