    Wifi has stopped working
    wifi pi3
    3485
    • RetroWilly
      RetroWilly last edited by
      Hello people,
      After a long run of running without problems i encountered a annoying thing on my Pi3
      After the 4.0.2 update my wifi had stopped working, even worse is that even a clean install with recovery won't start it anymore. When i fill in the right information in the SSID and password fields i get a Wifi Configuration Error, and it refuses to connect. My ethernet is working tho.
      There is no overclock present, simply because i didn't need it yet.
      It always worked flawlessly, So could this be a hardware issue?
      Thanks in Advance
      Hello :)
      • azvarel
        azvarel last edited by
        Strange, checked installing a previous version on another sd? Here it works normally, do this test before condemning rpi3
        Zodian Theme | #SNESProject
        • RetroWilly
          Well, after trying different new installations, none of them saw any networks. Had to send it back and the wifi module was damaged.
          Getting a new one, since it still is under warranty of 2 years.
          Thanks for the reply 🙂
          Hello :)
          • azvarel
            Good thing it's under warranty.
            Here get damaged, goodbye, would have to buy another. I do not remember if there is a production lot number, or a serial number, to report this to raspberrypi.org 😃
            • Raphael Bueno Hatencia
              Raphael Bueno Hatencia last edited by Raphael Bueno Hatencia
              I had a problem with the wifi after upgrading it to 4.1 unstable. My ethernet was working nicely, only wifi had problem.
              On recalbox.config do you see your wifi name and password correctly? OK That's your SHARE folder right?
              Now do the same on the SHARE_INIT folder, recalbox.conf file, wifi name and password probably is empty, soo fill it up.
              Mine worked correctly after this.
              Hope it works for you =D
              RetroWilly Stef11 2 Replies Last reply Reply Quote 1
              • RetroWilly
                RetroWilly @Raphael Bueno Hatencia last edited by
                @Raphael-Bueno-Hatencia
                Thanks for the reply, however the wifi module onboard was broken, somehow... Tried different builds and images. and none worked.
                Today i received my new Pi3, so tomorrow i can start building again.
                Hello :)
                • Stef11
                  Stef11 @Raphael Bueno Hatencia last edited by
                  @Raphael-Bueno-Hatencia +1
                    strange, i got problem with the wifi again.
                    Even changing wifi info on recalbox.conf on both share and share_init it dosnt work again.
                    Anyone knows if recalbox can connect to a hidden ssid wifi?
                    • pguillot
                      pguillot last edited by
                      Same problem with my own rpi3 : The system doesn't detect my Wifi interface (I think wifi interface's name is wlan0 in recalbox).
                      Check with ifconfig -a : no wlan0 interface displayed
                      Check with ifconfig up wlan0 : ifconfig: SIOCGIFFLAGS: No such device
                      In dmesg, no wifi presence in messages : https://framabin.org/?3ec4d68142c4a33c#bJiY0Kbskl94zicIJvWucgZypgUU3ssOhk7p9pAw/HY=
                      Find in /sys/devices/ :
                      find . -name address
                      ./virtual/net/lo/address
                      ./platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1:1.0/net/eth0/address
