    Update from 4.0.2 to 4.1.0 unstable
    update 4.0.2 4.1.0 unstable
    16662
    • duri3
      duri3 last edited by
      How can I update from 4.0.2 to 4.1 unstable?
      • DjLeChuck
        DjLeChuck last edited by
        You must set your version type to unstable in recalbox.conf
        • duri3
          I did that already and also rebooted still no update found. Will try again later.
          • DjLeChuck
            DjLeChuck last edited by DjLeChuck
            Another option is to make a clean install directly with the image: https://archive.recalbox.com/updates/v1.0/unstable/
            • duri3
              Downgrade possible without backup?
              • DjLeChuck
                It's a link for v4.1 unstable so not a downgrade.
                I think you can't downgrade.
                • duri3
                  Ok thanks for your help.
