    p5yk0Station2 [PS1-Case]
    Your recalbox
    p5yk0station2 [ps1-case]
    • p5yk0
      p5yk0 last edited by
      alt text
      p5yk0Station2
      PS1 Case including:
      • RasPi3
      • 160GB HDD
      • Adapter for PlayStation gamepads (manually soldered)
      • GPIO ON/OFF switch
      • Hardware ON/OFF switch
      • 3.5A / 5V supply
      • LED stripe for glow-effect
      Its not pretty because I just pushed inside what i needed without thinking, but I learned for future projects 🙂
      alt text
      alt text
      alt text
      alt text
      You can change the Pi OS-card without disassembling the case.
      alt text
      alt text
      Like I said, in the inside it looks so bad because i didn't think while pulling all together.
      But I hope you like it 🙂
        you didn't use the original PS power switch ? I see 2 switches on the left of your PS1.
        Have you used the gamecon driver for the original PS pads ?
        p5yk0 1 Reply Last reply Reply Quote 0
        • p5yk0
          p5yk0 @Substring last edited by
          @Substring i used an usb converter that already recognised 2 gamepads on the first startup. Even without pads plugged in.
          I didn't use the original power switch in this build, because there was not enough space for it left. Maybe next time 🙂
          • p5yk0
            p5yk0 @p5yk0 last edited by
            But I learned much from this project. I am happy it works and don't look back on the outside. If you wondered why it's called "p5yk0station2", the "first" p5yk0station was a Mini-ITX-PC inside the PS1 Case, with use of the original switches, but it failed with heat problems 😞
            alt text
            Next project will be something inside a Commodore64 case with use of it's keyboard. But this time, i plan first, then build 😄
            • xphere
              xphere last edited by
              New Commodore 64 project? ckech this, it can give you some ideas 🙂 http://www.xphere.me/articles/c64pi-project/
