    overclock
    overclock
    • chriswr81
      chriswr81 last edited by
      bonjour comment savoir si l'overclock marche ?
      • ian57
        ian57 Staff last edited by
        en mode console :
        $ cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_cur_freq
        $ cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq
        $ cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq
        • ian57
          Ou bien plus complet le script suivant avec en plus les températures :
          #!/bin/bash
          cpuTemp0=$(cat /sys/class/thermal/thermal_zone0/temp)
          cpuTemp1=$(($cpuTemp0/1000))
          cpuTemp2=$(($cpuTemp0/100))
          cpuTempM=$(($cpuTemp2 % $cpuTemp1))
          CpuSpeedCurrent=$(cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_cur_freq)
          #echo $CpuSpeedCurrent
          CpuSpeedMin=$(cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq)
          #echo $CpuSpeedMin
          CpuSpeedMax=$(cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq)
          #echo $CpuSpeedMax
          CpuSpeedCurrent1=$(($CpuSpeedCurrent/1000))
          CpuSpeedMin1=$(($CpuSpeedMin/1000))
          CpuSpeedMax1=$(($CpuSpeedMax/1000))
          echo Raspberry Temperatures:
          echo -----------------------
          echo CPU temp"="$cpuTemp1"."$cpuTempM"'C"
          echo GPU $(vcgencmd measure_temp)
          echo Raspberry Speed:
          echo Current Speed : $CpuSpeedCurrent1 MHz
          echo Minimum Speed : $CpuSpeedMin1 MHz
          echo Maximum Speed : $CpuSpeedMax1 MHz
