    Recalbox ´Daddelkiste´ (V4.1 - build 42)
    Your recalbox
    recalbox ´daddelkiste´ v4.1 build
    • Ratte
      Ratte last edited by Ratte
      Hi @all
      I started with the PI three months ago.
      No idea how to use it, no Linux skills .. nothing.
      I only heard about retrogaming on the PI and started with a short visit on RetroPi and changed very fast to RecalBox.
      It is absolute amazing, the frontend is made for kids, total easy to use.
      I just wanted to build a gamingmachine for my son, after four weeks it is perfect.
      Including customized intro & splashscreen, roms and all the required settings.
      Recalbox is simply great!
      Meanwhile i bought a second PI for me as a testmachine.
      I started with projects like overclocking (stable at CPU1350 / GPU500 / RAM500) and now i like to try to integrate UAE / VICE Emulation.
      If i could, i would change the coming C64 and Amiga Emulation in a DTV64 Emulation and CD32-Emulation.
      Both versions a pure gamingmachines and can be 100% controlled by normal controllers.
      And both systems are able to use normal C64 or Amiga software if it is really needed.
      Greetings from germany.
      Ratte
      (Amiga-User - www.a1k.org)
      •2 x Raspberry Pi model: Pi 3 B
      •Recalbox version (build) : "unstable" 4.1 build 42
      •Controller(s): 3 x Speedlink Torid
      •Raspberry Pi model: Pi ZeroW
      •Raspberry Pi model: Pi 3B @ 1350/500/500 MHz
      •Raspberry Pi model: Pi 3B+ @ 1550/500/500 MHz
