    Moonlight - Spiele editieren
    Emulatoren Arcade/PC/Konsole
    moonlight spiele editieren
    • noxx
      noxx last edited by
      Hallo
      habe nun endlich Moonlight am laufen. Bei einigen Spielen zeigt
      Moonlight keine Beschreibung und kein Cover an.
      Kann man das manuell editieren?
      Habs mit dem Universal Scraper XML probiert, aber da funktionierte
      nicht.
        Substring @noxx last edited by
        @noxx hi
        Game covers are taken from thegamesdb but it can happen this site is down. You can manually edit scraping data if you're brave, fearless and courageous !
        • noxx
          noxx last edited by
          is there no editor available. i mean a tool like ember media manager (for kodi movies eg) if you know
          it.
            @noxx the gamelist file is just a xml file ... Or maybe you can press select on the game and edit metadata from there, but you need a keyboard plugged
