    Emulateur n64 : pas en plein écran ?
    plein
    • Ren34
      Ren34 last edited by
      Bonsoir,
      Ma recalbox fonctionne parfaitement, mais j'ai un dernier problème avec l'emulateur n64.
      Je n'arrive pas à configurer mupen64 pour ne pas avoir l'image en timbre poste sur ma TV LCD Philips 42PFL9632d (102 cm).
      Voici les modes vidéo supportés :
      # tvservice -m DMT
      Group DMT has 3 modes:
         mode 4: 640x480 @ 60Hz 4:3, clock:25MHz progressive
         mode 9: 800x600 @ 60Hz 4:3, clock:40MHz progressive
         mode 16: 1024x768 @ 60Hz 4:3, clock:65MHz progressive
      # tvservice -m CEA
      Group CEA has 18 modes:
         mode 1: 640x480 @ 60Hz 4:3, clock:25MHz progressive
         mode 2: 720x480 @ 60Hz 4:3, clock:27MHz progressive
         mode 3: 720x480 @ 60Hz 16:9, clock:27MHz progressive
         mode 4: 1280x720 @ 60Hz 16:9, clock:74MHz progressive
         mode 5: 1920x1080 @ 60Hz 16:9, clock:74MHz interlaced
         mode 6: 720x480 @ 60Hz 4:3, clock:27MHz x2 interlaced
         mode 7: 720x480 @ 60Hz 16:9, clock:27MHz x2 interlaced
         mode 16: 1920x1080 @ 60Hz 16:9, clock:148MHz progressive
         mode 17: 720x576 @ 50Hz 4:3, clock:27MHz progressive
         mode 18: 720x576 @ 50Hz 16:9, clock:27MHz progressive
         mode 19: 1280x720 @ 50Hz 16:9, clock:74MHz progressive
         mode 20: 1920x1080 @ 50Hz 16:9, clock:74MHz interlaced
         mode 21: 720x576 @ 50Hz 4:3, clock:27MHz x2 interlaced
         mode 22: 720x576 @ 50Hz 16:9, clock:27MHz x2 interlaced
      (prefer) mode 31: 1920x1080 @ 50Hz 16:9, clock:148MHz progressive
         mode 32: 1920x1080 @ 24Hz 16:9, clock:74MHz progressive
         mode 33: 1920x1080 @ 25Hz 16:9, clock:74MHz progressive
         mode 34: 1920x1080 @ 30Hz 16:9, clock:74MHz progressive
      le timbre poste le plus gros est obtenue avec cette solution :
      Edit your ~/configs/mupen64/mupen64plus.cfg file, then switch your resolution :
      from
      # Width of output window or fullscreen width
      ScreenWidth = 640
      # Height of output window or fullscreen height
      ScreenHeight = 480
      to
      ScreenWidth = 800
      ScreenHeight = 600
      You'll use the same resolution than your video mode defined in your ~/recalbox.conf file "n64.videomode=DMT 9 HDMI".
      A l'aide, SVP ?
      L'un d'entre vous a t'il une solution magique ?
      Cordialement,
      Ren34
      • Ren34
        Hello,
        Juste un petit up...
        Cordialement,
        Ren34
          C'est ta TV qui ne veut pas afficher le DMT 4 en plein ecran, c'est tout.
