    [RESOLU] Cle wifi Realtek non supportée
    bluetooth
    2692
    • kasi
      kasi last edited by
      Bonjour, En premier lieu, merci pour recalbox que j'aime beaucoup :). J'ai acheté spécifiquement un dongle wifi qui fonctionne sous linux mais pas de chance il ne fonctionne pas sous recalbox... Voici le contenu de dmesg : [ 3.222121] usb 1-1.4: new high-speed USB device number 6 using dwc_otg [ 3.322578] usb 1-1.4: New USB device found, idVendor=0bda, idProduct=8179 [ 3.322604] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 3.322615] usb 1-1.4: Product: 802.11n NIC [ 3.322626] usb 1-1.4: Manufacturer: Realtek [ 3.322637] usb 1-1.4: SerialNumber: 00E04C0001 [ 3.402068] usb 1-1.5: new low-speed USB device number 7 using dwc_otg [ 3.522544] usb 1-1.5: New USB device found, idVendor=046d, idProduct=c521 [ 3.522569] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 3.522580] usb 1-1.5: Product: USB Receiver [ 3.522592] usb 1-1.5: Manufacturer: Logitech [ 3.545253] input: Logitech USB Receiver as /devices/platform/bcm2708_usb/usb1/1-1/1-1.5/1-1.5:1.0/0003:046D:C521.0004/input/input3 [ 3.545897] hid-generic 0003:046D:C521.0004: input,hidraw3: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-bcm2708_usb-1.5/input0 [ 3.572216] input: Logitech USB Receiver as /devices/platform/bcm2708_usb/usb1/1-1/1-1.5/1-1.5:1.1/0003:046D:C521.0005/input/input4 [ 3.632650] hid-generic 0003:046D:C521.0005: input,hiddev0,hidraw4: USB HID v1.11 Device [Logitech USB Receiver] on usb-bcm2708_usb-1.5/input1 [ 3.715231] r8188eu: module is from the staging directory, the quality is unknown, you have been warned. [ 3.722528] Chip Version Info: CHIP_8188E_Normal_Chip_TSMC_D_CUT_1T1R_RomVer(0) [ 3.747996] random: nonblocking pool is initialized [ 3.753972] usbcore: registered new interface driver r8188eu [ 7.875193] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup [ 7.875427] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [ 17.275223] r8188eu 1-1.4:1.0: Direct firmware load for rtlwifi/rtl8188eufw.bin failed with error -2 [ 17.275262] r8188eu 1-1.4:1.0: Firmware rtlwifi/rtl8188eufw.bin not available [ 17.275277] MAC Address = c4:6e:1f:20:05:50 [ 17.284671] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready [ 17.339468] usb 1-1.4: USB disconnect, device number 6 [ 17.340061] R8188EU: ERROR indicate disassoc [ 88.533073] bcm2708_fb_pan_display(0,0) returns=16 [ 399.036827] usb 1-1.2: USB disconnect, device number 4 [ 421.032038] usb 1-1.4: new high-speed USB device number 8 using dwc_otg [ 421.132510] usb 1-1.4: New USB device found, idVendor=0bda, idProduct=8179 [ 421.132530] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 421.132542] usb 1-1.4: Product: 802.11n NIC [ 421.132553] usb 1-1.4: Manufacturer: Realtek [ 421.132564] usb 1-1.4: SerialNumber: 00E04C0001 [ 421.135576] Chip Version Info: CHIP_8188E_Normal_Chip_TSMC_D_CUT_1T1R_RomVer(0) Serait-il possible d'ajouter le driver ? Merci
        Bonjour tu peux peut être tenté de l'ajouter manuellement : https://github.com/lwfinger/rtl8188eu/blob/master/rtl8188eufw.bin
        • kasi
          kasi last edited by
          Merci pour le retour. Une fois le firmware téléchargé, quelle est la procédure pour l'installer ?
            Bonjour il faudrait trouver le dossier rtlwifi dans l'architecture de recalbox via ssh.
            • kasi
              kasi last edited by
              Ça fonctionne ! Merci 🙂
                Bonjour Procédure :
                wget https://github.com/lwfinger/rtl8188eu/blob/master/rtl8188eufw.bin
                cp  ~/rtl8188eufw.bin /lib/firmware/rtlwifi/rtl8188eufw.bin
                  Hello, je te conseille d'ouvrir une issue sur le github, en expliquant le problème et la solution. Comme ça retroboy intégrera le pilote à la recalbox, et tu ne sera pas obligé de faire la manip en manuel à chaque installation.
                    Salut, https://github.com/digitalLumberjack/recalbox-os/issues/230
